When running "rosrun rosserial_python serial_node.py /dev/ttyACM0" I get the error message "wrong checksum for topic id and msg". After that it may continue to connect but the error "Serial Port read returned short (expected 78 bytes, received 5 instead)." comes up, or it may just not connect and keep trying. Whats weirder is if I restart the PC and run the code it works fine, I can launch RVIZ, with "roslaunch robot_description robot_description.py" and it will show me the range sensor and move about as i move my hand to and from the sensor. The next time I run it I get the above errors.
The code I am using is below. pretty basic for the tf stuff, really just copied the arduino copy as a test
//////////////////LIBRARIES///////////////////
#include <NewPing.h>
#include <ros.h>
#include <ros/time.h>
#include <sensor_msgs/Range.h>
#include <tf/transform_broadcaster.h>
//////////////////ROS Vars and OBJECTS///////////////////
ros::NodeHandle  nh;
sensor_msgs::Range range_msg;
ros::Publisher pub_range( "/ultrasound", &range_msg);
geometry_msgs::TransformStamped t;
tf::TransformBroadcaster sonar_broadcaster;
char base_link[] = "/base_link";  //set the TF child frame
char odom[] = "/odom";
char frameid[] = "/ultrasound";
//////////////////SONAR Vars and OBJECT///////////////////
int sonar_pin =12;
NewPing sensor(sonar_pin, sonar_pin, 25);
void setup()
  nh.initNode();
  nh.advertise(pub_range);
  sonar_broadcaster.init(nh);
  t.header.frame_id =  frameid;
  t.child_frame_id = base_link;
  range_msg.radiation_type = sensor_msgs::Range::ULTRASOUND; //set the message type and the sensor radiation type
  range_msg.header.frame_id = frameid;
  range_msg.field_of_view = (10.0/180.0) * 3.14;
  range_msg.min_range = 0.0;
  range_msg.max_range = 10;
  digitalWrite(sonar_pin, HIGH); //turn internal pull-up resistor on
long range_time;
void loop()
  //publish the adc value every 50 milliseconds
  //since it takes that long for the sensor to stablize
  if ( millis() >= range_time )
    t.transform.translation.x = 1.0;
    t.transform.rotation.x = 0.0;
    t.transform.rotation.y = 0.0;
    t.transform.rotation.z = 0.0;
    t.transform.rotation.w = 1.0;
    t.header.stamp = nh.now();
    sonar_broadcaster.sendTransform(t);
    range_msg.range = sensor.ping_in();
    range_msg.header.stamp = nh.now();
    pub_range.publish(&range_msg);
    range_time =  millis() + 28;
  nh.spinOnce();
Originally posted by AgentNoise on ROS Answers with karma: 38 on 2016-01-17
Well I figured out the checksum part of the issue. I was using frameid for both my tf broadcaster and the range_msg frame header id's. When I changed frameid to odom for the broadcaster it cleared it up.
I am still getting the "Serial Port read returned short" error
Edit: It appears the new ping library is what is causing the issue. If I use the function from the example it works just fine
Originally posted by AgentNoise with karma: 38 on 2016-01-17
Comment by ahendrix on 2016-01-17:
Depending on how the ping library is implemented, it might be blocking interrupts while it waits for a response. Try calling ping_in before you publish your transform.
Comment by AgentNoise on 2016-01-17:
That seems to be close to the trick. I set it to do the range_msg first, then do the transform. I also it on a timer so there is a 50 or 250ms break between range_msg and the transform. That kind of works but after a minute or so it looses connection, reconnects and gets the error Creation of
