I am having problems with installation of Indigo in UBUNTU 14.04.3 LTS Desktop 64 Bit. I followed the installation instructions provided on ROS website. But following problems are occuring.
At step 1.3 when i run following in terminal:
sudo apt-key adv --keyserver hkp://pool.sks-keyservers.net --recv-key 0xB01FA116
following msg is displayed:
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.AyKV0NvoaE --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://pool.sks-keyservers.net --recv-key 0xB01FA116
gpg: requesting key B01FA116 from hkp server pool.sks-keyservers.net
?: pool.sks-keyservers.net: Host not found
gpgkeys: HTTP fetch error 7: couldn't connect: Connection timed out
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
Edit:
Since i m a beginner in Linux environment. I do not know much about the system and its requirements. It is also possible may be I have not configured the repositories properly. Bcoz following command is also not working properly.
sudo apt-get update
When i run it following message is displayed.
Err http://packages.ros.org trusty InRelease
Err http://archive.ubuntu.com trusty InRelease
Err http://extras.ubuntu.com trusty InRelease
Err http://archive.ubuntu.com trusty-updates InRelease
Err http://archive.ubuntu.com trusty-backports InRelease
Err http://archive.ubuntu.com trusty-security InRelease
Err http://archive.canonical.com trusty InRelease
Err http://packages.ros.org trusty Release.gpg
Could not resolve 'packages.ros.org'
Err http://archive.ubuntu.com trusty Release.gpg
Could not resolve 'archive.ubuntu.com'
Err http://archive.ubuntu.com trusty-updates Release.gpg
Err http://archive.ubuntu.com trusty-backports Release.gpg
Err http://extras.ubuntu.com trusty Release.gpg
Could not resolve 'extras.ubuntu.com'
Err http://archive.canonical.com trusty Release.gpg
Could not resolve 'archive.canonical.com'
Err http://archive.ubuntu.com trusty-security Release.gpg
Reading package lists... Done
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty/InRelease
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty-updates/InRelease
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty-backports/InRelease
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty-security/InRelease
W: Failed to fetch
http://archive.canonical.com/ubuntu/dists/trusty/InRelease
W: Failed to fetch
http://extras.ubuntu.com/ubuntu/dists/trusty/InRelease
W: Failed to fetch
http://packages.ros.org/ros/ubuntu/dists/trusty/InRelease
W: Failed to fetch
http://packages.ros.org/ros/ubuntu/dists/trusty/Release.gpg
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty/Release.gpg
W: Failed to fetch
http://extras.ubuntu.com/ubuntu/dists/trusty/Release.gpg
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty-updates/Release.gpg
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty-backports/Release.gpg
W: Failed to fetch
http://archive.ubuntu.com/ubuntu/dists/trusty-security/Release.gpg
W: Failed to fetch
http://archive.canonical.com/ubuntu/dists/trusty/Release.gpg
W: Some index files failed to download. They have been ignored, or old ones used instead.
Originally posted by sajid on ROS Answers with karma: 1 on 2016-01-13
Comment by gvdhoorn on 2016-01-13:
Could you try the following: sudo apt-key adv --keyserver p80.pool.sks-keyservers.net:80 --recv-key 0xB01FA116
and report back here?
Comment by sajid on 2016-01-14:
I tried this. It also gives same message.
Comment by Nouman Tahir on 2016-01-14:
seems you are behind some proxy server, else try changing to main fetch server in software sources.
Comment by gvdhoorn on 2016-01-14:
First: you cannot apt-get update
until you've set up your keys properly. Second:
seems to point to a problem with your network configuration. Are you behind a proxy? Can you browse the internet normally? Can you ping archive.ubuntu.com
successfully?
Also: please don't post an answer, unless you can actually answer your own question. If you have additional information or updates, please edit your original question (use the edit link/button for that). For console copy/pastes, please format using the Preformatted text button (101010
