hello, i have git cloned rgbdslam_v2 package on my ros workspace as instructed here: https://github.com/felixendres/rgbdslam_v2
but when i try to execute "rosdep install rgbdslam_v2" i get following error:
ERROR: Rosdep cannot find all required resources to answer your query Missing resource rgbdslam_v2 ROS path [0]=/opt/ros/indigo/share/ros ROS path [1]=/opt/ros/indigo/share ROS path [2]=/opt/ros/indigo/stacks
i am using ros indigo.
Thank you
Originally posted by kaygudo on ROS Answers with karma: 11 on 2015-12-27
Two things to mention here,
  1. The package name is rgbdslam, not rgbdslam_v2. If you look in the launch files this is how it is referred to. So try running rosdep install rgbdslam.
  2. Based on the error output from Rosdep, it doesn't look like you have a catkin workspace setup. Did you clone it into /opt/ros/indigo/share? You should setup a catkin workspace as per the tutorials, http://wiki.ros.org/catkin/Tutorials, clone RGBDSLAM_V2 into there, then you can execute catkin_make to build the package.
Also, I've posted this same response in you previous question, http://answers.ros.org/question/223093/ros-packages-for-rgbd-slam-with-kinect/, but I would suggest not repeating the same question in two separate posts. Just stick to one, and if you find the responses helpful mark it as such. That way other users have less posts to look through when looking for answers.
Originally posted by Steven_Daniluk with karma: 606 on 2015-12-27
