I go through this tutorial. In 2.3.2 I run this command:
wstool init src -j5 https://raw.github.com/yujinrobot/yujin_tools/master/rosinstalls/indigo/kobuki.rosinstall
I have an error:
fatal: unable to access 'https://github.com/yujinrobot/yocs_msgs.git/': gnutls_handshake() failed: A TLS packet with unexpected length was received.
Exception caught during install: Error processing 'yocs_msgs' : [yocs_msgs] Checkout of https://github.com/yujinrobot/yocs_msgs.git version indigo into /home/nadya/kobuki/src/yocs_msgs failed.
ERROR in config: Error processing 'yocs_msgs' : [yocs_msgs] Checkout of https://github.com/yujinrobot/yocs_msgs.git version indigo into /home/nadya/kobuki/src/yocs_msgs failed.
How can I solve this problem?
Originally posted by nampi on ROS Answers with karma: 77 on 2015-12-26
This looks like a problem with github's service. I suspect that if you try again it will work.
Originally posted by tfoote with karma: 58457 on 2015-12-30
