I want to start or stop some ros nodes remotely. As I want to control a robot by my Android mobile phone through WIFI, and the robot maybe has no keyboard or displayer, so I cannot start the ros node by input "rosrun" or "roslaunch" in the terminal, and I want to use the smart phone to control some ros nodes, like start or stop them. For example, I want to let the robot to draw a map by GMapping node, so I press a button on my smart phone, and the Gmapping node run, then I press another button on my smart phone, the Gmapping node stops. And I have writed a node that could communicate with the smart phone.
I have been looking for the methods for a long time, and I cannot find a perfect method. I find this method link text that proposed by DimitriProsser is really good, however he only tell us the way to start.
So I want to know, are there other methods to achieve my goal? Thank you a lot!
Originally posted by tanghz on ROS Answers with karma: 130 on 2015-12-25
Comment by AutoCar on 2019-01-22:
How do you connect your smart phone to the robot?
Comment by billy on 2019-01-22:
I've done it using rosbridge and a webbrowser. I'm sure there are several ways.
But the mods are going to give you a hard time for asking a question using an answer on an unrelated topic. : (
Comment by jayess on 2019-01-23:
@AutoCar please don't use an answer to ask a question. This isn't a forum. You can ask a new question and reference this question instead.
3 Answers 3
I think you can do it using launch files, I never used it in the end, but it works for starting and stopping nodes programmatically (as long as it is one you previously launched programmatically)
http://answers.ros.org/question/203154/is-it-possible-to-run-and-quit-launch-files-from-code-inside-a-node/
Originally posted by nickw with karma: 1504 on 2015-12-25
Comment by tanghz on 2015-12-25:
Thank you very much, I will try it. It would be better if there's a C++ tutorial. I think maybe I have to learn the Python programming language.
Comment by tanghz on 2015-12-27:
Thank you very much, now I solved it, I have answered my own question. Thank you very much.
For example, there is a launch file named "rplidar.launch" and located in the "rplidar_ros" package, after I start the launch file, the ros node name is "rplidarNode", then I start and stop it in the ROS C++ code:
system("roslaunch rplidar_ros rplidar.launch");  //start
system("rosnode kill rplidarNode");              //stop
By the way, remember to new a thread, or the code would block and you cannot stop the node.
Originally posted by tanghz with karma: 130 on 2015-12-27
Comment by sonictl on 2016-12-07:
what do you mean"new a thread"? I mean, the code blocks and how to solve the block?
From https://www.theconstructsim.com/launch-node-using-ros-program/
import roslaunch
node = roslaunch.core.Node("other_pkg", "pkg_executable")
launch = roslaunch.scriptapi.ROSLaunch()
launch.start()
script = launch.launch(node)
Couldn't find the cpp equivalent way though
