I have been using the ros_control interface to implement a position controller to use both in Simulation (Gazebo) and on a real robot. My implementation inherits from control_base.h and I implement hardware_interface::PositionJointInterface.
My problem is that I would like to know the frequency of the update rate (base class code shown below) such to perform interpolation between desired and target joint positions such to follow a desired velocity.
 /// Calls \ref update only if this controller is running.
 void updateRequest(const ros::Time& time, const ros::Duration& period)
if (state_ == RUNNING)
  update(time, period);
Is there a method that gives me back the update rate of this function (above). Is it in the Time and Duration variables ? I have so fare failed to find a good tutorial which explains in detail the usage of control_base.h etc.. any pointers would be welcome.
Originally posted by gpldecha on ROS Answers with karma: 285 on 2015-12-10
Comment by gvdhoorn on 2015-12-10:
I may be misunderstanding you, but isn't period the inverse of what you are asking?
Comment by gpldecha on 2015-12-10:
yes, it is have just figured it out.. was not use to using ros::time and ros::Duration
Simply can get the frequency by doing period.toSec();
Originally posted by gpldecha with karma: 285 on 2015-12-10
