Hey folks,
I am using a 2D SLAM with Navigation stack and Gmapping. My odometry is not so accurate and once I start to move I slightly drift from the real position. The localization algorithm on gmapping compensates my error but the problem is that is a bit slow for my application. I receive a correction almost every 5 secs and I want to make it faster like amcl which does the same thing almost in real time (The problem with amcl is that it only works if you have a map and I want to do slam). I went through the parameters available on gmapping and couldn't find any thing related to the rate of updates that I am receiving from localization.
Any ideas? Thank you very much in advance
Originally posted by mohsen1989m on ROS Answers with karma: 397 on 2015-12-09
Check out the parameter "map_update_interval" Gmapping wiki. This parameter corresponds to interval between map updates. Its default value is 5 sec.
Originally posted by gp with karma: 166 on 2016-05-19
