I've just upgraded to ROS Jade and Gazebo 5.0 and am having problems with my robot model.
When I take out my lidar node, my world works with both $ gazebo myworld.world and $roslaunch mylaunch.launch where mylaunch wraps myworld.world. But when I add my hoyoyo lidar (as used to work in Indigo), it works with $ gazebo myworld.world but segfaults when I run gazebo through roslaunch. Any ideas?
Here's what I add to sdf for the lidar: model://hokuyo 0.45 0 0.45 0 0.15 0 hokuyo::link chassis 0 0 1 0 0
Originally posted by charles.fox on ROS Answers with karma: 120 on 2015-11-20
Some more info on this:
If I remove the hoyuko from the model.sdf and add it manually to the scene using the Gazebo GUI: Running gazebo directly -- this works and inserts a 3D model lidar with a visible blue ray
Running via roslaunch: -- it inserts the 3D lidar model but no blue rays are seen -- suggests something wrong
Originally posted by charles.fox with karma: 120 on 2015-11-20
Comment by charles.fox on 2015-11-20:
OK the problem is that the GPU laser plugin isn't working under roslaunch since I moved to Jade/Gaz5.0. If I go back to non-GPU then it works again, <controller:gazebo_ros_laser name="gazebo_ros_laser_controller" plugin="libgazebo_ros_laser.so">
could this be a bug in the latest gpu plugin ?
