When I attempt to install the prerequisites (OSRF sources for DDS) on the ros2 install I find a key problem. For example, when I type:
sudo apt-key adv --keyserver ha.pool.sks-keyservers.net --recv-keys D2486D2DD83DB69272AFE98867170598AF249743
it times out with the msg:
gpg: requesting key AF249743 from hkp server ha.pool.sks-keyservers.net gpg: keyserver timed out gpg: keyserver receive failed: keyserver error
Reading the net some have said to add port 80 to the command, but when I use:
sudo apt-key adv --keyserver ha.pool.sks-keyservers.net:80 --recv-keys D2486D2DD83DB69272AFE98867170598AF249743
it does not recognize that host and gives me: gpgkeys: no keyserver host provided gpg: keyserver internal error gpg: keyserver receive failed: keyserver error
I had no problem installing the original ros. Any advice appreciated.
Regards, Nolan
Originally posted by Nolan on ROS Answers with karma: 16 on 2015-11-11
Actually I fixed this myself. You go to the MIT PGP Key Server (http://pgp.mit.edu/) - input the text string into the search and do the search. You will probably have to put 0x in front of your string. You then copy the key and paste it into a text file, which you can import on the command line via gpg --import key.txt
I did have a problem farther downstream however. When I tried to run the talker and listener it could not find a library. The error msg was:
error while loading shared libraries: libddskernel.so: cannot open shared object file: No such file or directory
I assume I need to get DDS now, so any advice on that?
Regards, Nolan
Originally posted by Nolan with karma: 16 on 2015-11-11
Comment by gvdhoorn on 2015-11-12:
Nolan, ROS2 is currently in alpha and rather experimental. I suggest you report issues you encounter while testing/developing at ros2/ros2/issues.
As to your problem: that is not really ROS2 specific, but seems more like a network issue, local to your infra.
Comment by Sidd on 2017-01-17:
Were you able to figure this out?
Comment by gvdhoorn on 2017-01-18:
@Sidd: things have changed so much since November last year that it could very well be that you have a different problem.
In any case, I would still advice you to post an issue over at ros2/ros2/issues.
Comment by Sidd on 2017-01-19:
Thanks, I think I missed out on a dependency before installing ros2.0. Carefully went through all the steps again, and can confirm that the installation page for ros2 (https://github.com/ros2/ros2/wiki/Linux-Development-Setup) works perfectly.
