Hello,
I am receiving a sparse point cloud from a monocular slam algorithm. My question is if octomap_mapping is suitable for obstacle detection if my input pointcloud is sparse and I do not use a laser as sensor? If so, what changes would have to be made to octomap?
EDIT: Thanks for the reply. I configured the launch file of octomap and remapped it to the right point cloud topic, but nothing occurs. I checked the publisher topics of octomap, but I get the message that the topics have not been published yet. What could be the cause of this? Could you give me any hint about this please.Also I was not sure about the configuration of the following line in the launch file: param name="sensor_model/max_range" value="5.0"
Originally posted by Lolita390 on ROS Answers with karma: 31 on 2015-11-11
Octomap per default will use a pointcloud to update it's map representation. For the updating, it should not matter how sparse it is. Of course, depending on what application you want to use the octomap for, you could run into problems due to the sparse data, for instance if obstacle data is missing and your robot runs into things.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2015-11-11
Comment by Lolita390 on 2015-11-13:
I cannot launch octomap. The following warning comes up : "Nothing to publish, octree is empty". The frame I write in the launch file is the same as the fixed frame in rviz, which is "world". No transform is required, since the slam algorithm outputs the point cloud already in the world frame
What could the problem be?
