Hello everybody, I have compiled and installed from source OpenCV 3.0 and the project I had now throws a segmentation fault error. I tracked down the callback that causes it
void imageCallback(const sensor_msgs::ImageConstPtr &msg){
  cv_bridge::CvImagePtr cv_image;
  cv_image = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::RGB8);
  (cv_image->image).copyTo(frame_);
It seems that cv_bridge has a problem with the new version of the library.
For this specific project I can use OpenCV 2.x without any problem, however for other projects (both ROS and non-ROS) I have to use OpenCV 3.0.
How can I solve the problem?
Originally posted by Mago Nick on ROS Answers with karma: 385 on 2015-10-17
Is this with cv_bridge installed from ros-jade-cv-bridge and your from-source OpenCV? If so, that is most likely the issue: binary compatibility is only guaranteed when all packages that depend on OpenCV depend on the exact same version.
Edit:
Yes, this is the case. Is there any way I can edit my CMakeList.txt to force link with another OpenCV version?
There is (something like find_package(OpenCV 3.0 REQUIRED)), but I'm not sure that is what you want.
I can install the 2.x one along with the 3.0 Do you believe is a good idea?
If you installed any ROS Jade packages that depend on cv_bridge, you should already have an OpenCV 2 version installed. The issue is that you are probably linking your executable with cv_bridge, which pulls in OpenCV 2 dependencies, but also with OpenCV 3, which won't work.
If I remember correctly, @Vincent Rabaud has been working on OpenCV 3 ROS integration. He might be able to work out the best way to do this.
Originally posted by gvdhoorn with karma: 86574 on 2015-10-18
Comment by Mago Nick on 2015-10-19:
Yes, this is the case. Is there any way I can edit my CMakeList.txt to force link with another OpenCV version? I can install the 2.x one along with the 3.0 Do you believe is a good idea?
I see. What I meant was not to force link to OpenCV 3.0 but to the built in OpenCV of ros
Comment by gvdhoorn on 2015-10-19:\
Unfortunately downgrading OpenCV is not an option
and
This seems conflicting to me: if you can actually use OpenCV2, then there would be no issue, right?
No, there would not. I probably explained myself wrong. What I meant was that I could not unistall OpenCV 3.0. At the moment I do not know how to link to the built in version of ros. The OpenCV 3.0 are needed for another project. Therefore, is fine to me to use the older ones to compile this package
Ok, so could you please update your original question with some more details? If I understand you correctly, you have:
  1. ROS nodes that should just use OpenCV2
  2. an installation of OpenCV3 which you only need for non-ROS projects?
Not exactly. I have:
  1. A ROS project with independent ROS workspace that requires (apparently) OpenCV 2
  2. Other project bot ROS (that will have their own workspace) and non-ROS
hope this cleared out a bit
Not really. I'm not sure how a binary ros-jade-cv-bridge could be linked at runtime against your from-source OpenCV 3, unless you are also doing find_package(OpenCV) in your CMakeLists.txt, and that is pulling in CV3 libs.
Ok. I am actually doing as you are suggesting, but this implies that the software links to the new version of OpenCV. How should I do to link it to the old version?
To get CMake to find the old version, you can try something like find_package(OpenCV 2 REQUIRED), which should find the older version. You'll want to (build,run)_depend on libopencv-dev (in >= Indigo).
The only way to use OpenCV 3 with your other ROS projects would be to build everything in opencv_vision from source, making sure it finds your new version, or by not using opencv_vision at all, being very careful, and just link your node(s) with OpenCV 3. But that will likely be brittle.
Comment by mariam on 2016-04-21:
Hi, I have the exact same problem mentioned above and I've tried adding find_package(OpenCV 2 REQUIRED) to my CmakeLists but it doesn't work. How can I (build,run)_depending on libopencv-dev ?
