Hi, I'm doing the tutorials from ROS-Industrial, and i have a problem with this:
http://aeswiki.datasys.swri.edu/rositraining/indigo/Exercises/3.6
In the steps 5 and 6 from the first part i Have this problem
jaam002@jaam002:~/industrial_training/training/work/3.6$ rosrun lesson_move_group lesson_move_group
[ INFO] [1444515389.737938520]: Loading robot model 'abb_irb2400'...
[ INFO] [1444515389.893979856]: Loading robot model 'abb_irb2400'...
[ INFO] [1444515390.713263586]: Ready to take MoveGroup commands for group manipulator.
terminate called after throwing an instance of 'class_loader::LibraryUnloadException'
  what():  Attempt to unload library that class_loader is unaware of.
Abortado (`core' generado)
the robot plan succesfully the path, but it doesn't execute the path.
Originally posted by jaam002 on ROS Answers with karma: 25 on 2015-10-10
The errors you listed (LibraryUnloadException) are a known issue when disposing of a MoveGroup object (see here), but should not affect the observed planning or execution.
Check the terminal window in which you launched the move_group node (not the same window as above) for additional error messages. Are you sure that the planning was completed successfully? The ROS-I tutorial you reference tries to move the robot to a random joint position, which is not always reachable by the robot. You may see failure messages related to "unreachable position" or similar.
Originally posted by Jeremy Zoss with karma: 4976 on 2015-10-13
Comment by jaam002 on 2015-10-13:
thanks so much Jeremy, i could finally execute the path, it was just a mistake with the rviz
