hi,
i try to use https://github.com/ros2/rttest , but when i want to build the examples, it returns errors when running make
rttest/build/include/rttest/rttest.h:29:21: error: expected ‘:’, ‘,’, ‘;’, ‘}’ or ‘__attribute__’ before ‘=’ token
size_t iterations = 0,
and some other lines with the same style of error ? in rttest.h is a struct, with the first entry with the line of above error ?
including stddef.h
or changing size_t
to unsigned int
, doesnt change anything from the style of error ?
thanks for help flo
Originally posted by inflo on ROS Answers with karma: 406 on 2015-10-10
