Hi folks,
I am trying to use the gmapping node which subscribes to tf (tf/tfMessage) and scan (sensor_msgs/LaserScan) topics but the published topics (map and map_metadata) are unknown. I guess the problem is that I am publishing tf (tf2_msgs/tfMessage) instead of tf (tf/tfMessage) but I don't know how to solve it.
Any ideas?
Thank you very much in advance
I launch gmapping using the following code
  <node pkg="gmapping" name="slam_gmapping" type="slam_gmapping" args="scan:=scan" respawn="false" output="screen">
  </node>
Edit: Here is my tf Tree
image description
And my rviz view:
image description
My topics being published:
image description
And my node graphs
image description
Originally posted by mohsen1989m on ROS Answers with karma: 397 on 2015-10-01
Comment by wsAndy on 2015-10-01:
Hi, your question is that when you use rostopic echo /map and there is none map data, right ?
If you use gmapping, you also need odometry message ( nav_msgs/Odometry) if you want to create map. You can test it with stage_ros. image description
image description
Originally posted by wsAndy with karma: 224 on 2015-10-01
Comment by mohsen1989m on 2015-10-02:
Thank you for your answer. I am trying to do the mapping with my robot, I created a similar tf Tree unless the laser frame is "base_laser" instead of "base_laser_link". I still have problem. In rviz I get an error in front of Map/Transform : No transform from [ ] to [map]
Comment by wsAndy on 2015-10-02:
Well, please check your TF tree. Or put more details about your problem.
Thank you for your help, I added more information to the question :) Looking forward to your answer
Comment by wsAndy on 2015-10-04:
change the fixed frame to map, have a try. I wonder if you have the data of map? try rostopic echo /map
Comment by mohsen1989m on 2015-10-04:
Thank you for your answer, it is solved. It was a problem with rviz ...
Woo, good luck!
