Hi all,
I have a question regarding my robot rotating often while using frontier exploration, also it rotates just before it reaches the goal?
also the costmap does mark and clear with the laser scan (asus xtion- depthimage_to_laserscan) but the ultrasonic sensor does not mark or clear the costmap?
(based on husky exploration)
Is there anything wrong with the configuration??
costmap_common.yaml
footprint: [[-0.230,-0.16],[-0.230, 0.16],[0.230,0.16],[0.23,-0.16]]
footprint_padding: 0.01
robot_base_frame: base_link
update_frequency: 3.0
publish_frequency: 2.0
transform_tolerance: 0.5
resolution: 0.099
obstacle_range: 1.5
raytrace_range: 1.5
#layer definitions
static:
map_topic: /map
subscribe_to_updates: true
obstacles_laser:
observation_sources: laser
laser: {data_type: LaserScan, clearing: true, marking: true, topic: scan, inf_is_valid: true}
expected_update_rate: 0.07
inflation:
inflation_radius: 0.05
range_sensor_layer:
expected_update_rate: 0.125
clear_threshold: 0.1
mark_threshold: 0.1
no_readings_timeout: 0.2
topics: ["/ultrasound1"]
costmap_exploration.yaml
track_unknown_space: true
global_frame: map
rolling_window: false
plugins:
- {name: external, type: "costmap_2d::StaticLayer"}
- {name: explore_boundary, type: "frontier_exploration::BoundedExploreLayer"}
#Can disable sensor layer if gmapping is fast enough to update scans
- {name: obstacles_laser, type: "costmap_2d::ObstacleLayer"}
- {name: inflation, type: "costmap_2d::InflationLayer"}
explore_boundary:
resize_to_boundary: false
frontier_travel_point: middle
#set to false for gmapping, true if re-exploring a known area
explore_clear_space: false
local_costmap.yaml
global_frame: odom
rolling_window: true
plugins:
- {name: range_sensor_layer, type: "range_sensor_layer::RangeSensorLayer"}
global_costmap.yaml
global_frame: odom
plugins:
planner.yaml
recovery_behaviour_enabled: true
NavfnROS:
allow_unknown: true # Specifies whether or not to allow navfn to create plans that traverse unknown space.
default_tolerance: 0.5 # A tolerance on the goal point for the planner.
TrajectoryPlannerROS:
# Robot Configuration Parameters
acc_lim_x: 15.0
acc_lim_theta: 15.0
max_vel_x: 0.15
min_vel_x: 0.8
max_vel_theta: 0.5
min_vel_theta: -0.5
min_in_place_vel_theta: 0.7
holonomic_robot: false
escape_vel: -0.2
# Goal Tolerance Parameters
yaw_goal_tolerance: 0.2
xy_goal_tolerance: 0.3
latch_xy_goal_tolerance: false
# Forward Simulation Parameters
sim_time: 1.0
sim_granularity: 0.02
angular_sim_granularity: 0.02
vx_samples: 6
vtheta_samples: 20
penalize_negative_x: true
controller_frequency: 7.0
# Trajectory scoring parameters
meter_scoring: true # Whether the gdist_scale and pdist_scale parameters should assume that goal_distance and path_distance are expressed in units of meters or cells. Cells are assumed by default (false).
occdist_scale: 0.01 #The weighting for how much the controller should attempt to avoid obstacles. default was0.5
pdist_scale: 0.4 # The weighting for how much the controller should stay close to the path it was given . default 0.6
gdist_scale: 0.8 # The weighting for how much the controller should attempt to reach its local goal, also controls speed default 0.8
heading_lookahead: 0.25 #How far to look ahead in meters when scoring different in-place-rotation trajectories
heading_scoring: true #Whether to score based on the robot's heading to the path or its distance from the path. default false
heading_scoring_timestep: 0.8 #How far to look ahead in time in seconds along the simulated trajectory when using heading scoring (double, default: 0.8)
dwa: false #Whether to use the Dynamic Window Approach (DWA)_ or whether to use Trajectory Rollout
simple_attractor: false
publish_cost_grid_pc: true
# Oscillation Prevention Parameters
oscillation_reset_dist: 0.25 #How far the robot must travel in meters before oscillation flags are reset (double, default: 0.05)
escape_reset_dist: 0.1
escape_reset_theta: 0.1
DWAPlannerROS:
# Robot configuration parameters
acc_lim_x: 2.5
acc_lim_y: 0
acc_lim_th: 3.2
max_vel_x: 0.5
min_vel_x: 0.0
max_vel_y: 0
min_vel_y: 0
max_trans_vel: 0.5
min_trans_vel: 0.1
max_rot_vel: 1.0
min_rot_vel: 0.2
yaw_goal_tolerance: 0.1
xy_goal_tolerance: 0.2
# # Forward Simulation Parameters
# sim_time: 2.0
# sim_granularity: 0.02
# vx_samples: 6
# vy_samples: 0
# vtheta_samples: 20
# penalize_negative_x: true
# # Trajectory scoring parameters
# path_distance_bias: 32.0 # The weighting for how much the controller should stay close to the path it was given
# goal_distance_bias: 24.0 # The weighting for how much the controller should attempt to reach its local goal, also controls speed
# occdist_scale: 0.01 # The weighting for how much the controller should attempt to avoid obstacles
# forward_point_distance: 0.325 # The distance from the center point of the robot to place an additional scoring point, in meters
# stop_time_buffer: 0.2 # The amount of time that the robot must stThe absolute value of the veolicty at which to start scaling the robot's footprint, in m/sop before a collision in order for a trajectory to be considered valid in seconds
# scaling_speed: 0.25 # The absolute value of the veolicty at which to start scaling the robot's footprint, in m/s
# max_scaling_factor: 0.2 # The maximum factor to scale the robot's footprint by
Originally posted by miguel on ROS Answers with karma: 170 on 2015-09-29
