I am trying my hand at robot navigation. I am not able to comprehend, the following differences,
  1. Difference in the odometry data from sources like wheel or visual and the output generated by state estimators like robot_pose_ekf packages. Because they both seem to have the same message format.
  2. I am able to understand the transform between baselink and different sensor coordinate frames. But what is the difference between world, map, nav, odom and base_link frame. In some cases I find, base_footprint and base_stabilized coordinate frames too.
  3. In the tf map, should there be one fixed frame and can odom_frame be made as fixed frame in the presence of /map or /world frame?
Originally posted by boon on ROS Answers with karma: 111 on 2015-09-26
  1. Data from sources like wheel encoders or visual odometry can be noisy and might not be good enough. Therefore, robot_pose_ekf combines measurements coming from different sources (like IMU, Wheel encoders, Visual Odometry) using EKF to provide a better estimate of the 3D pose of the robot.
  2. REP-105 explains different coordinate frames. base_footprint is just a projection of base_link on the ground.
  3. Yes.. odom_frame can be made a fixed frame in presence of other frames. I am not 100% sure about this. Can someone confirm this?
Hope it helps.
Originally posted by Naman with karma: 1464 on 2015-09-26
