Hi, I want to subscribe some data which is published from rosserial_arduino in cpp
I coded like this in sketch
std_msgs::Float64 vx_msg;
ros::Publisher vx_pub("vx_msg", &vx_msg);
void setup() {
  nh.getHardware() -> setBaud(57600);
  nh.initNode();
  nh.advertise(vx_pub);
void loop() {
  nh.spinOnce();
  vx_msg.data = 1; // publish linear velocity
  vx_pub.publish (&vx_msg);
This is for calculating odometry . As I can't use encoder, I have to publish constant velocity which I compute.
I can check that the message is published well because I can watch the data with ' $ rostopic echo'
so I coded with global function in .cpp file
##Like this
double vel_x;
void vx_odom (const vx_pub::vx_msg &vx_msg)
    vel_x = vx_msg.vx.msg.data;
There are tutorials about how to subscribe string message . But, I don't have idea if It is Float64 type.
What is the form of subsribing float 64 type data ?
Originally posted by Ros_junior on ROS Answers with karma: 1 on 2015-09-11
Please check again the Subscriber Tutorial and try to understand it. Especially read carefully the the paragraph where the commands are described.
Instead of what you did here:
you have to put in the respective message type into the callback function. So for you it would be:
void vx_odom (const std_msgs::Float64::ConstPtr& vx_msg)
Originally posted by mgruhler with karma: 12390 on 2015-09-17
