Hi there, I am using Octomapping in ROS to generate an occupancy grid but I want to use it for 2d Navigation so is there a possibility to convert the optimized Octree to a Quadtree ?
Originally posted by ktiwari9 on ROS Answers with karma: 61 on 2015-09-09
Well, it is not really converting it to a Quadtree. But as you are using ROS for 2D navigation, you should be able to use the ocotmap_server_multilayer (LINK) which publishes multilayered nav_msgs::OccupancyGrids. Check out the 3d_navigation for a demo video.
Having a quick look at the source code, I'd say that you would have to adjust it a bit.
Maybe, using the downprojected map of the octomap_server is already enough for you, but I had problems with this (too much clutter)...
If there are better ways, I'd be happy to know as well ;-)
Originally posted by mgruhler with karma: 12390 on 2015-09-10
Comment by jwlifly on 2016-05-03:
hi, i came across the same problem, but after i modify the octomap_server_multilayer.cpp(/opt/ros/groovy/stacks/octomap_mapping), how do i rebuild the file to make the system know that the file has been changed? I tried rosmake, but i didn't work? Any suggestion? Thank you
Comment by mgruhler on 2016-05-03:
Check out the source code into a catkin workspace. You should never manually change any files int /opt/....
FYI, the current ROS LTS release is indigo (two releases ahead of groovy), and the next release, kinetic (four ahead) just reached beta. You should probably change to a newer release..
I have worked it out. Thanks.
