Hi,all I install ros-by-exanple-indigo code on my computer.And I prepare to test pocketsphinx for speech recognition.However,Once I run the .launch file there will be a mistake which will kill the program.Steps and mistakes as follow.
run command:
 roslaunch pocketsphinx robocup.launch
terminal display:
   ... logging to /home/aicrobo/.ros/log/cabf42a4-563d-11e5-8ab7-e8b1fc053d0e/roslaunch-ubuntu-5253.log
Press Ctrl-C to interrupt
started roslaunch server http://ubuntu:49975/
SUMMARY
PARAMETERS
 * /recognizer/dict: /opt/ros/indigo/s...
 * /recognizer/lm: /opt/ros/indigo/s...
 * /rosdistro: indigo
 * /rosversion: 1.11.13
NODES
    recognizer (pocketsphinx/recognizer.py)
core service [/rosout] found
process[recognizer-1]: started with pid [5271]
the rosdep view is empty: call 'sudo rosdep init' and 'rosdep update'
[INFO] [WallTime: 1441726151.014228] Launch config: gconfaudiosrc
/opt/ros/indigo/lib/pocketsphinx/recognizer.py:68: SyntaxWarning: The publisher should be created with an explicit keyword argument 'queue_size'. Please see http://wiki.ros.org/rospy/Overview/Publishers%20and%20Subscribers for more information.
  self.pub = rospy.Publisher('~output', String)
[INFO] [WallTime: 1441726151.017618] Starting recognizer...
  File "/opt/ros/indigo/lib/pocketsphinx/recognizer.py", line 177, in <module>
    start = recognizer()
  File "/opt/ros/indigo/lib/pocketsphinx/recognizer.py", line 73, in __init__
    self.start_recognizer()
  File "/opt/ros/indigo/lib/pocketsphinx/recognizer.py", line 80, in start_recognizer
    self.pipeline = gst.parse_launch(self.launch_config)
glib.GError: no element "gconfaudiosrc"
  File "/opt/ros/indigo/lib/python2.7/dist-packages/rospy/core.py", line 399, in signal_shutdown
    h()
  File "/opt/ros/indigo/lib/pocketsphinx/recognizer.py", line 131, in shutdown
    gtk.main_quit()
RuntimeError: called outside of a mainloop
[recognizer-1] process has died [pid 5271, exit code 1, cmd /opt/ros/indigo/lib/pocketsphinx/recognizer.py __name:=recognizer __log:=/home/aicrobo/.ros/log/cabf42a4-563d-11e5-8ab7-e8b1fc053d0e/recognizer-1.log].
log file: /home/aicrobo/.ros/log/cabf42a4-563d-11e5-8ab7-e8b1fc053d0e/recognizer-1*.log
all processes on machine have died, roslaunch will exit
shutting down processing monitor...
... shutting down processing monitor complete
done
Thanks!
Originally posted by rubber bread on ROS Answers with karma: 3 on 2015-09-08
Comment by ahendrix on 2015-09-08:
Please do not repost; it clutters the forums. If someone with relevant knowledge knows the answer to your question, they will respond. I have set your user status to 'moderated' for excessive reposting.
Comment by rubber bread on 2015-09-09:
sorry,there're some mistakes with my Firefox.I can't upload the question (However, it has already uploaded) So ,the question uploaded like repost.
You are missing the gstreamer 0.10 element gconfaudiosrc, try installing it. Depending on your Linux Distribution it is named something like gstreamer0.10-gconf.
Originally posted by Humpelstilzchen with karma: 1504 on 2015-09-09
Thanks a lot.After I runsudo apt-get install gstreamer0.10-gconf it worked
