After I run the docker container of osrf/ros, I got the following error, and the GUI not work!
$ docker run -it --security-opt="label:disable" --env="DISPLAY" --volume="/tmp/.X11-unix:/tmp/.X11-unix:rw" osrf/ros:indigo-desktop-full rqt
X Error: BadAccess (attempt to access private resource denied) 10
Extension: 130 (MIT-SHM)
Minor opcode: 1 (X_ShmAttach)
Resource id: 0x135
X Error: BadShmSeg (invalid shared segment parameter) 128
Minor opcode: 3 (X_ShmPutImage)
Resource id: 0x2000008
Originally posted by Lmaths on ROS Answers with karma: 11 on 2015-09-03
