Hello,
I have a rosbag in which a /tf topic is recorded.
I need to remap all tf frames in that bag which refer to the frame named '/world' to refer to a new frame named '/vision'. I tried the following but it is unfortunately not working:
rosrun tf tf_remap _mappings:='[{old: /world, new: /vision}]'
Am I missing something?
EDIT: I have also tried to do it from a launch file:
<launch>
  <node pkg="tf" type="tf_remap" name="tf_remapper" output="screen">
    <rosparam param="mappings">
      - {old: "/world",
         new: "/vision"}
    </rosparam>
  </node>
</launch>
but it's not working :(
Could it be that I am missing some argument when calling rosbag play?
EDIT 2: After searching, I found people saying that, in addition to running the tf_remap node, rosbag should be run as follows:
rosbag play x.bag /tf:=/tf_old
I tried it, and still it's not working :(
The tf_frames are still referring to /world rather than /vision.
Any help would be highly appreciated!!
Originally posted by beginner on ROS Answers with karma: 83 on 2015-08-26
Post score: 4
Comment by spmaniato on 2016-02-04:
Did you end up figuring this out? I would love to know the answer. Thanks!
Comment by OzzieTheHead on 2021-08-20:
I know this is not what you are asking but, for this use case I would just find&replace
I think I had the same problem and I found the following syntax to work from my launch file:
    [{old: depth_camera, new: /camera_rgb_optical_frame},{old: thermal_camera, new: /camera_optris_frame}]
  </rosparam>
</node>
<node pkg="rosbag" type="play" name="player" args="--clock $(arg bag_dir)/$(arg file)">
  <remap from="tf" to="tf_old" />
</node>
Bear in mind I was remapping two frames, so you probably won't need the comma. Also, my original frames didn't have a forward slash in front of them which is why I left it out.
You should then see a message printed to the console with something like the following:
Applying the following mappings to incoming tf frame ids {'depth_camera': '/camera_rgb_optical_frame', 'thermal_camera': '/camera_optris_frame'}
Originally posted by Stephen Vidas with karma: 131 on 2016-03-22
Post score: 5
Comment by engyasin on 2018-09-03:
and no qutation marks..
Comment by dj95 on 2020-05-07:
Can tf_remap be used without using bag files?
Comment by Remi_Tortue on 2023-07-12:
@dj95 Yes it can
