ı want use to imu on my robot. But ı cant understan how do I place my imu on my roboy. so imu see to which direction ?
my imu : http://wiki.ros.org/um7
http://i.imgur.com/MdeN9er.jpg
the feed direction robot will be imu's x direction ??
Originally posted by osmancns on ROS Answers with karma: 153 on 2015-08-26
it looks like the code takes this into account
Source file is here https://github.com/ros-drivers/um7/blob/indigo-devel/src/main.cpp
// IMU outputs [w,x,y,z], convert to [x,y,z,w] & transform to ROS axes
    imu_msg.orientation.x =  r.quat.get_scaled(1);
    imu_msg.orientation.y = -r.quat.get_scaled(2);
    imu_msg.orientation.z = -r.quat.get_scaled(3);
    imu_msg.orientation.w = r.quat.get_scaled(0);
so looks like you put it with the x pointing forwards from the robot, fixing the device so the it looks the right way up from its packaging - the code flips the values round to match right hand rule.
Originally posted by nickw with karma: 1504 on 2015-08-26
Comment by osmancns on 2015-08-26:
Thanks @nickw. you think is it correct in this way : ????? http://i.imgur.com/UweLTQu.jpg
Comment by osmancns on 2015-08-27:
@nickw ı am not sure ???
Comment by nickw on 2015-08-27:
I would expect that to be correct - the test now is to run the node and check the values you get make sense and change in the way you would expect to if you change the robots orientation.
Comment by osmancns on 2015-08-28:
yes you are right...
