The ground usually isn't completely flat, so what I like to do is add a roll and pitch from an IMU to correct the laser scan frame before using it for gmapping and amcl.
I was planning to use http://wiki.ros.org/hector_imu_attitude_to_tf to publish base_frame with the roll and pitched added, and add the laser frame to base_frame.
The IMU on the robot is offset by a translation and rotation from the actual base link. hector_imu_attitude_to_tf just takes roll and pitch from sensor_msgs/Imu published, and publishes the TF. But what I need to do, is find roll and pitch of base frame from my IMU, and not just take the roll and pitch directly from the IMU itself.
Is there a way to find roll/pitch of base_frame from using TF as it is? Or is it something which requires calculation on my end and republish the IMU message before sending it into hector_imu_attitude_tf?
The system being run is ROS indigo on ubuntu 14.04. Thank you!
Originally posted by pwong on ROS Answers with karma: 447 on 2015-08-20
I was over thinking it. As long as the IMU was mounted on the robot rigidly, the roll and pitch doesn't need additional transforms/conversions done to the values themselves.
I ended up not using the hector_imu_attitude_to_tf node. My constraint was having an IMU be mounted with a rotation of -3.14 radians(in the x direction). I subscribed to the imu topic(add the offset), then included the roll/pitch to the base_link transform and odometry.
I don't think the hector_imu_attitude_to_tf_node allows for an imu which is mounted in a different orientation as the base_link.
Originally posted by pwong with karma: 447 on 2015-10-09
Comment by AlexR on 2016-10-05:
Hi, I have the same problem. Can you help me with my setup. Do I need to make separate tf for the roll and pitch or just fixing the tf for the /imu will suffice everything. I need to figure out the roll and pitch of the platform before doing anything with the laser scans. Thanks.
Comment by pwong on 2016-10-13:
Alex, I'm not sure how you are using your /imu frame, so I cant really answer your first question. In my application, my /base_link is connected to my /odometry frame, so all I had to do was put the roll/pitch straight into my /odometry frame, and my laser scan was fine.
