I've recently been learning about SLAM and have been attempting to implement EKF-SLAM in python. I've been using this great article as a guide. Some progress has been made, but I'm still confused by certain stages.
Firstly, does the inverse sensor model have to compute range and bearing, as opposed to cartesian coordinates? Why is this approach used?
Secondly, what format should my robot provide its heading in? Currently I just use a running offset from the origin angle (0), without wrapping it between 0 and 360. Turning right yields positive degrees, and left negative. I ask this as I assume the sensor model expects a certain format.
Thirdly, when computing the jacobians for adding new landmarks, (page 35) is Jz simply the absolute rotation of the robot (-540 degrees for example) plus the bearing the landmark was detected at?
And finally, what's the best approach for managing the huge covariance matrix? I'm currently thinking of a good way to 'expand' P when adding new landmarks.
Here's my current implementation: http://pastebin.com/r7wUMgY7
Any help would be much appreciated! Thanks.
  • $\begingroup$ Hi jabz and welcome to robotics SE. It would be best if you break up your post into multiple questions, since they each address different aspects of EKF SLAM. $\endgroup$
    – Paul
    Mar 28, 2015 at 4:22
  • $\begingroup$ @Paul Sure, I'll split off the unanswered questions as best I can. $\endgroup$
    – jub
    Mar 28, 2015 at 18:08
I've addressed your first two questions below.
Given your current state (which includes the pose of the robot and the position of the landmarks), the inverse sensor model predicts what the observation should be. In other words, if you have a laser scanner that reports the range and bearing of the landmark from your current pose, you want to compare that observation with what the inverse sensor model predicts. The reason why it is not converted to Cartesian coordinates is because the noise of the laser scanner observation is in range and bearing. Usually you want your observation model to generate a prediction whose form is as close to what your physical sensor provides as possible.
If the only place the heading is used is in cosines and sines, then it shouldn't matter. However, you need to be careful whenever you take the difference between two angles. For example 179 degrees minus -179 degrees gives 358 degrees. In reality, the difference is -2 degrees, (which is equivalent to 358 degrees if you know it must be wrapped), but an algorithm minimizing the error might think 358 degrees is a large error.
Also, the traditional 2D coordinate system has the angle being report with respect to the x-axis, with x forward, y left and z up. As a result, turning right should decrease the heading angle.
  • $\begingroup$ This was super helpful, thanks. Just to clear something up on the second question, I was meaning the rotation provided by the odometry every 'predict' step (not the current 'heading' control given to the robot). The 'x' grows up makes more sense now, even my sensor reports the samples counter clockwise. So internally I should use that model, but then flip everything when it comes to rendering the map? I think my confusion came from trying to have everything work in the graphical coordinate system, whereas as papers I've read expect the system you suggested. $\endgroup$
    – jub
    Mar 28, 2015 at 18:05
