Hello, After I have followed the tutorials , the connection between my turtlebot2 and the workstation still doesn't work, I have set ROS_MASTER_URI , ROS_HOSTNAME in both the workstation and the turtlebot netbook. when I'm trying to do : roslaunch turtlebot_bringup minimal.launch
(after I've ssh'd to the turtlebot netbook)
I get these errors:
core service [/rosout] found process[robot_state_publisher-1]: started with pid [2978] terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid process[diagnostic_aggregator-2]: started with pid [2980] terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid process[mobile_base_nodelet_manager-3]: started with pid [2982] terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid process[mobile_base-4]: started with pid [2984] terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid [robot_state_publisher-1] process has died [pid 2978, exit code -6, cmd /opt/ros/hydro/lib/robot_state_publisher/robot_state_publisher __name:=robot_state_publisher __log:=/home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/robot_state_publisher-1.log]. log file: /home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/robot_state_publisher-1*.log [diagnostic_aggregator-2] process has died [pid 2980, exit code -6, cmd /opt/ros/hydro/lib/diagnostic_aggregator/aggregator_node __name:=diagnostic_aggregator __log:=/home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/diagnostic_aggregator-2.log]. log file: /home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/diagnostic_aggregator-2*.log process[cmd_vel_mux-5]: started with pid [2986] terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid process[bumper2pointcloud-6]: started with pid [2988] [mobile_base_nodelet_manager-3] process has died [pid 2982, exit code -6, cmd /opt/ros/hydro/lib/nodelet/nodelet manager __name:=mobile_base_nodelet_manager __log:=/home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/mobile_base_nodelet_manager-3.log]. log file: /home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/mobile_base_nodelet_manager-3*.log terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid process[turtlebot_laptop_battery-7]: started with pid [2990] [mobile_base-4] process has died [pid 2984, exit code -6, cmd /opt/ros/hydro/lib/nodelet/nodelet load kobuki_node/KobukiNodelet mobile_base_nodelet_manager mobile_base/odom:=odom mobile_base/enable:=enable mobile_base/disable:=disable mobile_base/joint_states:=joint_states __name:=mobile_base __log:=/home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/mobile_base-4.log]. log file: /home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/mobile_base-4*.log [cmd_vel_mux-5] process has died [pid 2986, exit code -6, cmd /opt/ros/hydro/lib/nodelet/nodelet load yocs_cmd_vel_mux/CmdVelMuxNodelet mobile_base_nodelet_manager cmd_vel_mux/output:=mobile_base/commands/velocity __name:=cmd_vel_mux __log:=/home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/cmd_vel_mux-5.log]. log file: /home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/cmd_vel_mux-5*.log [bumper2pointcloud-6] process has died [pid 2988, exit code -6, cmd /opt/ros/hydro/lib/nodelet/nodelet load kobuki_bumper2pc/Bumper2PcNodelet mobile_base_nodelet_manager bumper2pointcloud/pointcloud:=mobile_base/sensors/bumper_pointcloud bumper2pointcloud/core_sensors:=mobile_base/sensors/core __name:=bumper2pointcloud __log:=/home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/bumper2pointcloud-6.log]. log file: /home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/bumper2pointcloud-6*.log [WARN] [WallTime: 1438594577.419304] Battery : unable to check laptop battery info [global name 'exceptions' is not defined] [WARN] [WallTime: 1438594577.422830] Battery : unable to check laptop battery state [global name 'exceptions' is not defined] [turtlebot_laptop_battery-7] process has finished cleanly log file: /home/turtlebot/.ros/log/ed2507e6-39c0-11e5-9712-c4d987c9f05e/turtlebot_laptop_battery-7*.log all processes on machine have died, roslaunch will exit shutting down processing monitor... ... shutting down processing monitor complete done
please help me.
Originally posted by tal_eldar on ROS Answers with karma: 33 on 2015-08-03
So I've found a way to make it work, apprently the problew was in " what(): locale::facet::_S_create_c_locale name not valid process" the solution is by : " export LC_ALL="C" " in my understanding it means that the code is written in C (language). if anybody can tell otherwise i will be happy to learn.
Originally posted by tal_eldar with karma: 33 on 2015-08-05
Comment by Nagarjun on 2020-11-15:
I didn't understand your solution, Can you please detail it?
