I have a node that subscribes to /joy topic, converts to /cmd_vel topic, and publishes to arduino via rosserial. I am receiving joy messages just fine, but when I
rosmsg show control/Velocity
(control is the name of the node, Velocity is the message), it says:
Unable to load msg [control/Velocity]: Cannot locate message [Velocity]: unknown package [control] on search path.
When I rostopic echo /cmd_vel, I get
Error: Cannot load message class for [control/Velocity]. Are your messages build?
I have tried many things. I believe that my environment variables are good, and I tried going into the root of my workspace, catkin_make clean, catkin_make, and source my devel/setup.sh file. Still, nothing seems to be working. My Velocity.msg file is in my CmakeLists.txt and the required build depends and run time depends are in my package.xml (build depend message_generation and run depend message_runtime).
Any advice would be helpful. Thanks!
Edit 1: CMakeLists.txt:
project(control)
find_package(catkin REQUIRED
  dynamic_reconfigure
  roscpp
  message_generation
  sensor_msgs
  nav_msgs
  sound_play
  std_srvs
  std_msgs
generate_dynamic_reconfigure_options(
  cfg/Control_Params.cfg
add_message_files(
   FILES
   Velocity.msg
generate_messages(
   DEPENDENCIES
   std_msgs
catkin_package(
  INCLUDE_DIRS include
  LIBRARIES control
  CATKIN_DEPENDS dynamic_reconfigure message_runtime
  DEPENDS system_lib
include_directories(
  ${catkin_INCLUDE_DIRS}
  include
  ../common
add_executable(control src/control.cpp)
add_executable(stopService src/stopService.cpp)
add_dependencies(control control_gencpp control_gencfg)
add_dependencies(stopService stopService_gencpp stopService_gencfg)
target_link_libraries(control
   ${catkin_LIBRARIES}
target_link_libraries(stopService
   ${catkin_LIBRARIES}
Originally posted by jbrown on ROS Answers with karma: 101 on 2015-07-23
Comment by gvdhoorn on 2015-07-24:
Please add (the relevant sections of) your CMakeLists.txt (remove any boilerplate comments first please). Without more info, we can only guess. Also: which version of ROS is this?
Comment by jbrown on 2015-07-24:
This is for ROS Indigo. I edited my question to include my CMakeLists.txt.
Comment by jbrown on 2015-07-30:
It looks to be an issue either with the code or the controller I am using. I am using a Moga Pro bluetooth controller. I set it up correctly.
Comment by jbrown on 2015-08-04:
This is on the Jetson TK1 board if anybody is interested.
Seems to me that http://wiki.ros.org/rosmsg#rosmsg_show is saying the syntax is package/messageType for rosmsg show. Your error message also says unknown package. So:
(control is the name of the node, Velocity is the messageType),
Try specifying package name before the slash, instead of a node name.
Originally posted by 130s with karma: 10937 on 2016-12-22
