I'm trying to use ueye_cam
package to control two uEye cameras: a UI122xSE-C and a UI223xSE-C. I've installed the IDS driver and I can use it to open both cameras. I'm trying to use rgb8.launch
to control the UI122xSE camera first. However, I get the following warning whenever I run this launch with that camera:
SUMMARY
PARAMETERS
* /rosdistro
* /rosversion
* /ueye_cam_nodelet/auto_exposure
* /ueye_cam_nodelet/auto_frame_rate
* /ueye_cam_nodelet/auto_gain
* /ueye_cam_nodelet/auto_white_balance
* /ueye_cam_nodelet/binning
* /ueye_cam_nodelet/blue_gain
* /ueye_cam_nodelet/camera_id
* /ueye_cam_nodelet/camera_intrinsics_file
* /ueye_cam_nodelet/camera_name
* /ueye_cam_nodelet/camera_parameters_file
* /ueye_cam_nodelet/camera_topic
* /ueye_cam_nodelet/color_mode
* /ueye_cam_nodelet/exposure
* /ueye_cam_nodelet/ext_trigger_mode
* /ueye_cam_nodelet/flash_delay
* /ueye_cam_nodelet/flash_duration
* /ueye_cam_nodelet/flip_lr
* /ueye_cam_nodelet/flip_upd
* /ueye_cam_nodelet/frame_rate
* /ueye_cam_nodelet/gain_boost
* /ueye_cam_nodelet/green_gain
* /ueye_cam_nodelet/image_height
* /ueye_cam_nodelet/image_left
* /ueye_cam_nodelet/image_top
* /ueye_cam_nodelet/image_width
* /ueye_cam_nodelet/master_gain
* /ueye_cam_nodelet/pixel_clock
* /ueye_cam_nodelet/red_gain
* /ueye_cam_nodelet/sensor_scaling
* /ueye_cam_nodelet/subsampling
* /ueye_cam_nodelet/white_balance_blue_offset
* /ueye_cam_nodelet/white_balance_red_offset
NODES
nodelet_manager (nodelet/nodelet)
ueye_cam_nodelet (nodelet/nodelet)
auto-starting new master
process[master]: started with pid [12676]
setting /run_id to 51881744-30ea-11e5-a04e-001cbf994206
process[rosout-1]: started with pid [12689]
started core service [/rosout]
process[nodelet_manager-2]: started with pid [12701]
[ INFO] [1437621866.152417884]: Initializing nodelet with 2 worker threads.
process[ueye_cam_nodelet-3]: started with pid [12719]
[ INFO] [1437621866.398732306]: Unable to open camera calibration file [/home/labrobotica/.ros/camera_info/camera.yaml]
[ WARN] [1437621868.876056765]: Could not load UEye camera 'camera' sensor parameters file /home/labrobotica/.ros/camera_conf/camera.ini (IS_FILE_WRITE_OPEN_ERROR)
[ WARN] [1437621868.876325235]: Camera configuration loaded into an unsupported color mode; switching to MONO8.
[ WARN] [1437621868.932790723]: Internal image scaling is not supported by camera
[ INFO] [1437621869.028831010]: UEye camera 'camera' initialized on topic /camera/image_raw
Width: 752
Height: 480
Left Pos.: -1
Top Pos.: -1
Color Mode: rgb8
Subsampling: 1
Binning: 1
Sensor Scaling: 1
Auto Gain: 1
Master Gain: 0
Red Gain: 0
Green Gain: 1
Blue Gain: 16
Gain Boost: 0
Auto Exposure: 1
Exposure (ms): 33
Auto White Balance: 1
WB Red Offset: 0
WB Blue Offset: 0
Flash Delay (us): 0
Flash Duration (us): 1000
Ext Trigger Mode: 0
Auto Frame Rate: 0
Frame Rate (Hz): 30.0087
Pixel Clock (MHz): 25
Mirror Image Upside Down: 0
Mirror Image Left Right: 0
How can I get the parameters? How can I calibrate the camera?
EDIT: I also have another question regarding the control of both cameras at the same time. Do I need just to modify rgb8.launch adding another ueye_cam_nodelet (like ueye_cam_nodelet2) with another camera_name (like camera2)?
Originally posted by Pinchi on ROS Answers with karma: 31 on 2015-07-22
