Maybe it is brand new but I've recently noticed I can install ros-indigo-opencv3. It installs into the /opt/ros/indigo. There is also a opencv 2.4.8 already installed into the system outside of /opt in /usr/lib/x86_64-linux-gnu/, and every ros package from the repositories linked against opencv is linked to that.
When I try to build a package that depends on cv_bridge it fails:
CMakeFiles/rotate_cam.dir/src/rotate_cam.cpp.o: In function `RotateImage::RotateImage()':
rotate_cam.cpp:(.text+0x6dc): undefined reference to `cv::imread(cv::String const&, int)'
CMakeFiles/rotate_cam.dir/src/rotate_cam.cpp.o: In function `cv::String::~String()':
rotate_cam.cpp:(.text._ZN2cv6StringD2Ev[_ZN2cv6StringD5Ev]+0x14): undefined reference to `cv::String::deallocate()'
CMakeFiles/rotate_cam.dir/src/rotate_cam.cpp.o: In function `cv::String::String(std::string const&)':
rotate_cam.cpp:(.text._ZN2cv6StringC2ERKSs[_ZN2cv6StringC5ERKSs]+0x69): undefined reference to `cv::String::allocate(unsigned long)'
And if I remove ros-indigo-opencv3 it builds fine. With VERBOSE=1 I don't see any trace of opencv3 includes or libraries (cv_bridge properly brings in 2.4.8 libraries, and includes /usr/include/opencv which is still 2.4.8).
The problem is that it is using opencv 3.0 headers and linking against 2.4.8, and breakage between those produces the link error.
When the a node dependent on opencv 2.4.8 builds it runs:
c++ ... -I/opt/ros/jade/include -I/usr/include/opencv ...
It seem like one problem is that opencv 3.0 is installed in the jade directories and 2.4.8 is in the usr directory- so it is using the wrong header files. But even when I correct this ordering the linker error still occurs.
What I'd like is to have opencv 3.0 available for special packages that need it (though they can't also link to cv_bridge, no mixing of 2.4.8 and 3.0 in the same package?).
I'm going to try to duplicate this problem on a small scale, it is possibly an artifact of something in one of my cmake files in my large workspace.
Ubuntu 14.04.2
Originally posted by lucasw on ROS Answers with karma: 8729 on 2015-07-18
Post score: 8
Comment by jeremya on 2015-09-28:
Any update on this? I working on a project with similar concerns.
Comment by lucasw on 2015-11-30:
Tried this with ros-jade-opencv3.0 and it fails the same way.
See https://github.com/ros-perception/vision_opencv/issues/79
@jeremya I was able to get opencv 3.0 installed from source to a non-standard location and have a specific package find_package it. ros-indigo-opencv3 seems just plain broken. http://answers.ros.org/question/213925/opencv30-ros-indigo/?answer=213928#post-id-213928
My current solution is to build OpenCV 3.0 from source and then install it into a location that is not on any paths. Then in the package
# don't use opencv as found by any prior running of find_package
unset(OpenCV_CONFIG_PATH CACHE)
unset(OpenCV_DIR CACHE)
set(TMP_PREFIX_PATH ${CMAKE_PREFIX_PATH})
set(CMAKE_PREFIX_PATH "$ENV{HOME}/special/install")
find_package(OpenCV 3.0 REQUIRED)
# restore CMAKE_PREFIX_PATH and other cached variables
# so nothing other package finds this opencv
set(CMAKE_PREFIX_PATH ${TMP_PREFIX_PATH})
include_directories(
  include
  ${catkin_INCLUDE_DIRS}
  ${OpenCV_INCLUDE_DIRS}
target_link_libraries(foo_node
  ${catkin_LIBRARIES}
  ${OpenCV_LIBS}
Originally posted by lucasw with karma: 8729 on 2015-12-01
Post score: 5
Comment by Thomas D on 2015-12-31:
With this solution do you still have the limitation that you can't use cv_bridge in the same node?
Comment by lucasw on 2016-01-19:
It does have that limitation- I haven't done it but cv_bridge could maybe be recompiled against cv 3.0 in the workspace.
Comment by cyberguy42 on 2016-02-23:
I spent hours trying to do this before finding this answer! I can confirm that cv_bridge can be used in the same node: recompile cv_bridge from source and use this approach for both your code and cv_bridge.
Comment by jtim on 2016-07-27:
@Cyberguy42 did you do something special to compile from source, because dpkg did not help me.
Comment by cyberguy42 on 2016-07-28:
I didn't use dpkg at all; I downloaded this package link text to my catkin workspace, applied the suggested changes to each affected CMakeLists, and compiled.
However, I did encounter issues making my program into a nodelet: it compiled fine, but crashed at run time. Debugging revealed that it was trying to call the 2.4.8 library. Static compiling of 3.0 into my program didn't fix the problem. Lesson: run 2.4.8 and 3.0 code in separate processes.
