Hi! I have a compass sensor and a odom sensor, this start in the position 0,0,0. The compass it's in the correct position but when i echo the odometry filtered It is delaying it will respect the GPS signal.
Any answer?
EDIT 1: This is a rosbag with the sensor topics https://www.dropbox.com/s/6kwbd1yaxixpf8m/rosbag.bag?dl=0 This is a tree graph, nodes graph and rviz capture. image description image description
Red color /odometry/filtered and green color position/GPS image description image description
The position GPS is in absolute coordinates. The ekf launch is this, with the base link compass transformation:
<!-- EKF -->
<launch>
<node pkg="tf" type="static_transform_publisher" name="link1_broadcaster" args="0.0 0.0 0.0 0.0 0.0
0.0 1.0 base_link compass 20" />
<node pkg="robot_localization" type="ekf_localization_node" name="ekf_localization" clear_params="true">
  <param name="frequency" value="30"/>
  <param name="sensor_timeout" value="0.1"/>
  <param name="two_d_mode" value="true"/>
  <param name="map_frame" value="map"/>
  <param name="odom_frame" value="odom"/>
  <param name="base_link_frame" value="base_link"/>
  <param name="world_frame" value="odom"/>
  <param name="odom0" value="position/gps"/>
  <param name="imu0" value="compass/data"/>
  <rosparam param="odom0_config">[true,  true,  false,
                                  false, false, false,
                                  false, false, false]</rosparam>
  <rosparam param="imu0_config">[false, false, false,
                                 false, false, true,
  <param name="odom0_differential" value="false"/>
  <param name="imu0_differential" value="false"/>
  <param name="imu0_remove_gravitational_acceleration" value="true"/>
  <param name="print_diagnostics" value="false"/>
  <!-- ======== ADVANCED PARAMETERS ======== -->
  <param name="odom0_queue_size" value="2"/>
  <param name="imu0_queue_size" value="10"/>
  <param name="debug"           value="false"/>
  <param name="debug_out_file"  value="/home/tmoore/Desktop/debug_ekf_localization.txt"/>
  <rosparam param="process_noise_covariance">[0.05, 0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.06, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.03, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.03, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.06, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.025, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.025, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.04, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.02, 0.0, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0,
                                              0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.015]</rosparam>
       <rosparam param="initial_estimate_covariance">[1e-9, 0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    1e-9, 0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    1e-9, 0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    1e-9, 0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    1e-9, 0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    1e-9, 0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    1e-9, 0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    1e-9, 0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    1e-9, 0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    1e-9,  0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     1e-9,  0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     1e-9,  0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     1e-9, 0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    1e-9, 0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    1e-9]</rosparam>
</node>
</launch>
Originally posted by Porti77 on ROS Answers with karma: 183 on 2015-07-14
Comment by Tom Moore on 2015-07-14:
Sorry, to clarify: you have wheel encoder odometry, a magnetometer, and a GPS? Are you using navsat_transform_node? Perhaps you can give me some more information about your setup.
Comment by 130s on 2015-07-15:
@Porti77 Better post the solution you found as an answer and mark it as an answer so that others can tell the question is solved.
Hi!! I already solved my problem , the error was that i wasnt including the time stamp in the topics of sensors and these become crazy the filter, now the system is working well!! Regards
Originally posted by Porti77 with karma: 183 on 2015-07-27
