Hi all,
I am new to ROS and Linux. I am using ROS Indigo on Ubuntu 14.04 LTS. I am trying to establish serial communication with an microcontroller using ROS serial package (https://github.com/wjwwood/serial). Came across an example program by garyservin (https://github.com/garyservin/serial-example). The program works well.
The instruction packet I want to send to MCU has start bytes "@@". However, when I try to publish to this to the topic "write" I get this error:
rostopic: error: Argument error: while scanning for the next token found character '@' that cannot start any token   in "<string>", line 1, column 1:
    @@1233
Similarly if I try to send a number I get this error:
ERROR: Unable to publish message. One of the fields has an incorrect type:
  field data must be of type str
The datatype used in the example program is std_msgs/String.
What I want to send is actually data in hex code. Something like 0x40 0x40 0x09 0x01 0x00 0x00 0x02 0x0d 0x0a
Could someone guide me on how to solve this problem?
UPDATE
#include <ros/ros.h>
#include <serial/serial.h>
#include <std_msgs/String.h>
#include <std_msgs/Empty.h>
serial::Serial ser;
void write_callback(const std_msgs::String::ConstPtr& msg){
    ROS_INFO_STREAM("Writing to serial port" << msg->data);
    ser.write(msg->data);
int main (int argc, char** argv){
    ros::init(argc, argv, "serial_example_node");
    ros::NodeHandle nh;
    ros::Subscriber write_sub = nh.subscribe("write", 1000, write_callback);
    ros::Publisher read_pub = nh.advertise<std_msgs::String>("read", 1000);
    try
        ser.setPort("/dev/ttyACM0");
        ser.setBaudrate(9600);
        serial::Timeout to = serial::Timeout::simpleTimeout(1000);
        ser.setTimeout(to);
        ser.open();
    catch (serial::IOException& e)
        ROS_ERROR_STREAM("Unable to open port ");
        return -1;
    if(ser.isOpen()){
        ROS_INFO_STREAM("Serial Port initialized");
    }else{
        return -1;
    ros::Rate loop_rate(5);
    while(ros::ok()){
        ros::spinOnce();
        if(ser.available()){
            ROS_INFO_STREAM("Reading from serial port");
            std_msgs::String result;
            result.data = ser.read(ser.available());
            ROS_INFO_STREAM("Read: " << result.data);
            read_pub.publish(result);
        loop_rate.sleep();
Thanks!
Originally posted by vinjk on ROS Answers with karma: 96 on 2015-07-09
Comment by ahendrix on 2015-07-09:
It looks like you're writing a node in python which is publishing to a topic with the std_msgs/String type. You should post the source for that program if you want help with it, or follow @William's suggestion and just modify the example program.
Comment by vinjk on 2015-07-09:
Sorry about that. The program is the same one made by garyservin (see the link). I've posted the program in my question for your convenience. It's C++ program.
The error message you post is clearly coming from a python program, and not for the sample code. If you're publishing to the write topic using rostopic, please include the exact command you're running.
Comment by vinjk on 2015-07-10:
This is the exact command I tried to run
rostopic pub /write -r 100 std_msgs/String @@1233
Comment by William on 2015-07-10:
Did you try putting the string you want to send in quotes?
@William I had tried that as well
This isn't the most efficient way to talk with your micro, you could just modify the example to write directly to you micro or you could modify the node to take an array of uint8_t's rather than a string.
Originally posted by William with karma: 17335 on 2015-07-09
tried as you suggested. Used std_msgs/UInt8MultiArray instead of std_msgs/String
void write_callback(const std_msgs::UInt8MultiArray::ConstPtr& msg){
    //ROS_INFO_STREAM("Writing to serial port " << msg->data);
Nothing is send or received
[character limit reached in prev comment so writing this here]
I executed this in another terminal
rostopic pub /write std_msgs/UInt8MultiArray '{data: [82, 79, 83]}' -r 1
Hi @William , @ahendrix
I solved the problem. I did as per William's suggestion used UInt8MultiArray datatype. But before writing it to the serial port I convert it to string.
    std::string str(msg->data.begin(), msg->data.end());
I used the command below (just an example) to publish to topic /write
rostopic pub /write std_msgs/UInt8MultiArray '{data: [64,64,11,1,1,1,2,208,32,13,10]}'
Originally posted by vinjk with karma: 96 on 2015-07-10
Thank you guys for your time.
