Hi I am trying to launch a static_transform_publisher from the tf package. It has the following syntax:
static_transform_publisher x y z yaw pitch roll frame_id child_frame_id period_in_ms
which should be called from a launch file like this
<launch>
    <node pkg="tf" type="static_transform_publisher" name="link1_broadcaster" args="1 0 0 0 0 0 1 link1_parent link1 100" />
</launch>
What I am trying to achieve is to load the parameters x y z yaw pitch roll from a calibration (.yaml) file, just as I can load rosparams using the rosparam load syntax:
<rosparam command="load" file="$(find rosparam)/example.yaml" />
But I can't find a way to use the values from the parameter server and pass them via the args= Argument. I am hoping to find a launchfile-based solution instead of writing a node, that basicaly does the same as the static_transform_publisher node.
Does anyone have a solution?
PS: I do not want to hardcode the values into the launch file, because they might change. Not during runtime, but in between runs.
Originally posted by cbandera on ROS Answers with karma: 123 on 2015-07-08
Post score: 5
Comment by dornhege on 2015-07-08:
My guess is that this is not possible.
Comment by luc on 2015-07-08:
You may want to edit the source so that those arguments are instead loaded via the parameter server instead of through the launch file.
Just stumbled upon this questions..
I would go for launch file arguments (http://wiki.ros.org/roslaunch/XML/arg):
<launch>
    <arg name="args" default="1 0 0 0 0 0 1 link1_parent link1 100"/>
    <node pkg="tf" type="static_transform_publisher" name="link1_broadcaster" args="$(arg args)"/>
</launch>
Maybe you should use one argument per parameter.
If you really want to use parameters, you can use this hackish solution that uses bash to append the arguments read by rosparam:
<launch>
    <param name="myargs" value="1 0 0 0 0 0 1 link1_parent link1 100"/> <!-- or elsewhere -->
    <node pkg="tf" type="static_transform_publisher" name="link1_broadcaster" launch-prefix="/bin/bash -c '$* `rosparam get myargs`' --"/>
</launch>
Originally posted by Mathias Lüdtke with karma: 1596 on 2015-11-06
Comment by cbandera on 2015-11-06:
Hi, thanks for your replay. I will test this next time. In the meantime, I have written my own "static_transform_publisher_node" which is able to accept rosparams, and can even read from our custom file format. So this solved it for me.
Comment by GuillaumeB on 2017-01-09:
It seems that the second hack doesn't work for me (ros indigo)
Comment by Mathias Lüdtke on 2017-01-14:
I have just run a test on kinetic and it works. And I am pretty sure I have tested it with indigo as well..
Comment by GuillaumeB on 2017-01-16:
Sorry, I just retried and it work. I don't know what was my test. Even the param overwrite work. Thx
Comment by Chrisando on 2017-01-26:
This hackish solution works for me. How can I use it with a namespace? For example get /"namespace"/sensor_pos_0' <group ns="tower_0"> <node pkg="tf" type="static_transform_publisher" name="sensor_pose_0" launch-prefix="/bin/bash -c '$* rosparam get /tower_0/sensor_pos_0`' --"/>
Comment by Mathias Lüdtke on 2017-01-27:
rosparam retrieve its data relative the to namespace of the . rosparam get /tower_0/param should work as well as rosparam get param. Please do not name your parameter the same as your node as it turns sensor_pos_0 into a namespace.
Comment by Chrisando on 2017-01-27:
Thank you @Mathias Lüdtke I works as you said.
