I wanted to do a relative import from my Python ROS node.
So I added a __package__ = 'my_package'
specification to the beginning of the file (right under the shebang). This is needed, because for a script, __package__ == "__main__"
, instead of the real package name.
Since then, I started receiving warnings when running the node using rosrun:
Parent module 'my_package' not found while handling absolute import from sensor_msgs.msg import PointCloud2
And, also, there was an error reported for the relative import:
Parent module 'my_package' not loaded, cannot perform relative import
It seems like the __package__
definition somehow messes up all other ROS imports.
So I tried putting this definition after all absolute imports, and right before the relative import. The same result, though.
Putting it after the relative import is obviously useless, because it is added to allow me to use relative imports.
The only way to get it working was to give up using relative import and use the normal absolute ROS package paths.
So the question is: Are relative imports supported in ROS scripts at all? If yes, how?
Originally posted by peci1 on ROS Answers with karma: 1366 on 2015-07-08
