I have a robot that I built in URDF that I am visualizing in RVIZ. I can control the joints using the gui tool or a rostopic pub command, but I am unable to build a publisher node to interface with the rviz visualization.
The rostopic pub works fine so I tried to build a ros package that would publish the joint information to the rviz visualization. "Rostopic echo /joint_states" lists the newly published command, but the rviz model does not move.
I am able to use the following command to move the robot using a terminal:
rostopic pub -1 /joint_states sensor_msgs/JointState '{header: auto, name: ['joint0', 'joint1', 'joint2', 'joint3'], position: [1, 0.5418, -1.7297, -3.1017], velocity: [], effort: []}'
Here is the code I am trying to build to publish the same information. I built it into a package that I am running:
#!/usr/bin/env python
import rospy
from sensor_msgs.msg import JointState
from std_msgs.msg import Header
def talker():
    pub = rospy.Publisher('joint_states', JointState, queue_size=10)
    rospy.init_node('joint_state_publisher')
    rate = rospy.Rate(10) # 10hz
    hello_str = JointState()
    hello_str.header = Header()
    hello_str.header.stamp = rospy.Time.now()
    hello_str.name = ['joint0', 'joint1', 'joint2', 'joint3']
    hello_str.position = [3, 0.5418, -1.7297, -3.1017]
    hello_str.velocity = []
    hello_str.effort = []
    pub.publish(hello_str)
    rate.sleep()
if __name__ == '__main__':
    try:
        talker()
    except rospy.ROSInterruptException:
        pass
After I run the package to move the robot, rostopic list shows the new state, but the robot has not moved in RVIZ.
Originally posted by kevlarkevlar on ROS Answers with karma: 25 on 2015-07-07
Comment by gvdhoorn on 2015-07-08:\
I can control the joints using the gui tool [..]
Which tool are you referring to here? rqt_publisher, joint_state_publisher or something else?
Comment by umar_anjum on 2022-01-27:
he is referring to joint_state_publisher_gui, http://wiki.ros.org/joint_state_publisher_gui
Comment by gvdhoorn on 2022-01-28:
That package didn't exist in 2015.
def talker():
    rate.sleep()
What do expect this does? You have no loop construct in there, and the rate is set to sleep for 0.1 seconds only. I can imagine that is not enough time for ROS to be able to successfully distribute your message to the rest of the system (especially not the first message). The talker() function will exit (and take all things in its scope with it) after a very short time.
Even for testing (so with static data), I'd recommend something like:
def talker():
      rate.sleep()
Originally posted by gvdhoorn with karma: 86574 on 2015-07-08
Comment by kevlarkevlar on 2015-07-08:
Thanks, that worked! I had never worked with static data publishing.
