I want to build a quad copter. I want to know how do we calculate thrust or lift generated by using a motor, I am not aware about the capacities of motor. So can you explain how to calculate thrust or lift generated by assuming a motor. And what is the maximum payload that a quad copter can lift for a given thrust.
This is actually quite complex and depends on a fair number of factors. You will need to know the specs of the motor, especially kV, but also its expected current draw and the internal resistance. Obviously, your choice of propellers will also have an effect, and so will your choice of powerplant. It also depends on the ambient air temperature and pressure.
There are online calculators that can help you in that regard, this one lets you pick some common motor models and has a lot of other variables to consider. It offers feedback that includes lifting capabilities, engine efficiency and heat generated by the motors, among other things.
It should also be noted, that the theoretical values from the calculator can be quite different from the actual values you'll see in reality, but its a good starting point for helping you choose suitable equipment.
  • $\begingroup$ I use eCalc all the time and it is always very accurate for me. $\endgroup$
    – Mark Omo
    Apr 15, 2015 at 2:48
  • $\begingroup$ the website is a useful tool to investigate options, however the question is more related to the logic of calculations, e.g. 1) estimate/calculate lift required (depends on 1.i) weight), 1.ii.)max forward speed (depends on the tilt angle required), 2) calculate RPM and torque required (depends on Lift), 3) calculate motor power output, 4) find the items (prop + motor + esc + battery + controller + structure + ...), 5) re-estimate weight, 6) re do the whole steps. $\endgroup$ May 14, 2015 at 2:22
