Hi,
I have a Asus Xtion sensor being driven by the Openni2_launch package. I subscribe to the "/camera/depth/image" topic and attempt to convert the ImageConstPtr& data type to an OpenCV Mat in a callback function utilising the cv_bridge package. Visualising the "/camera/depth/image" ROS topic in RQT, I get a high quality depth image as expected:
image description
However I can't seem to find an image type encoding (e.g. "8UC1") which OpenCV/cv_bridge accepts which results in an image similar to the one above. As an example, with the encoding "32FC1", this is the type of quality I get. I'm not entirely sure what I'm doing wrong!
image description
And here's the source code
// Callback function for time-synchronised RGB and depth images
void sync_callback(const sensor_msgs::ImageConstPtr& rgb, const sensor_msgs::ImageConstPtr& depth)
    // Convert ROS images to OpenCV
    cv::Mat rgb_image;
    cv::Mat depth_image;
    try
        rgb_image = cv_bridge::toCvShare(rgb, "mono8") -> image;
        depth_image = cv_bridge::toCvShare(depth, "32FC1") -> image;
    catch (cv_bridge::Exception& e)
        ROS_ERROR("Could not convert from ROS images to OpenCV type: %s", e.what());
Thanks in advance!
Originally posted by WillAndrew on ROS Answers with karma: 20 on 2015-07-02
Post score: -1
The output from openni2_camera is 32FC1, with measurements in meters. In the past I have converted to 32FC1, and then normalized in the range of ~0.5m to 5.5m. I haven't tried to compile my depth_viewer in a while, but it is probably a good starting spot.
Originally posted by fergs with karma: 13902 on 2015-07-04
Comment by WillAndrew on 2015-07-06:
Works really well, thanks!
This should works.
    cv_bridge::CvImagePtr depthImg = cv_bridge::toCvCopy(depth , sensor_msgs::image_encodings::TYPE_32FC1);
    //Normalize the pixel value
    cv::normalize(depthImg->image, depthImg->image, 1, 0, cv::NORM_MINMAX);
    imwrite("./depth.jpg", depthImg->image);
    ros::shutdown();
Originally posted by Po-Jen Lai with karma: 1371 on 2015-07-03
Comment by Humpelstilzchen on 2015-07-03:
My Xtion gives me a 16bpp image, so I would use 16UC1.
Comment by WillAndrew on 2015-07-03:
Thanks! but both of your suggestions didn't work (32FC1 resulted in the same black&white image, 16UC1 was just completely black..)
Comment by Po-Jen Lai on 2015-07-03:
Thx, I used 32FC1 for Kinect. But it's weird it cannot show properly.
Sorry I have to correct myself, 16UC1 is for image_raw, what does
rostopic echo /camera/depth/image --noarr
report for you?
My Kinect is borrowed from someone now, so I don't have one to test.
"encoding: 32FC1" for the Xtion
