I have a YAML file with a structure like the following:
field_a:
   field_a1: {field_b1, field_b2, ..., field_bM}
   field_a2: {field_b1, field_b2, ..., field_bM}
   field_aN: {field_b1, field_b2, ..., field_bM}
where field_a and field_bj are known a priori for all j, but field_ai are frequently changed by the user (i.e. can't be hard coded).
If I try to retieve the parameters field_ai using the C++ method getParam(...) or the command line rosparam get /field_a, what I get is everything in the tree hierarchy where /field_a is the root.
Is there a way to retrieve only the names of these field_ai and not their values? I could create another list with those names, but it not scale very well...
Thank you for your help!
Originally posted by alextoind on ROS Answers with karma: 217 on 2015-06-28
3 Answers 3
You can definitely try to parse this manually with XMLRPC (or probably with yaml-cpp).
What you have here should probably be a std::map of std::pair<std::string, std::vector<T>>, but this is not supported, as far as I know. Simpler types work.
If you would choose python, you could use the rospy.get_param_names() function.
Originally posted by mgruhler with karma: 12390 on 2015-06-30
You can parse the XmlRpcValue after doing getParam on field_a. ROS' version of XmlRpcValue adds an iterator type and begin()/end() calls, so you can iterate over a struct.
If in doubt, check the header in /opt/ros/XXX/include/XmlRpcValue.h for the API, not the official (non-ROS) docs.
Comment by mgruhler on 2015-07-03:
You're obviously right with checking the header in /opt/ros. I took the link which is linked from the ROS wiki Parameter Server page. Maybe we should put this note in there as well...
Comment by dornhege on 2015-07-03:
Updated. .
Thanks to both! I did not think about XmlRpc and the hint of using the iterator works like a charm!
This is the code for the example above:
std::vector<std::string> field_names;
XmlRpc::XmlRpcValue list;
if (!node_handle_.getParam("/field_a", list)) {
  ROS_ERROR("Can't find '/field_a' in the YAML configuration file.");
  return;
for (auto it = list.begin(); it != list.end(); it++) {
  field_names.push_back(it->first);
For the sake of completeness it->second is the the nested list {field_b1, field_b2, ..., field_bM}.
Originally posted by alextoind with karma: 217 on 2015-07-02
