Hello all;
I am trying to install ROS indigo in a new system, but keyserver is down:
alberto@OptiPlex-9010:~$ sudo apt-key adv --keyserver hkp://pool.sks-keyservers.net --recv-key 0xB01FA116
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.ryx941KSlA --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://pool.sks-keyservers.net --recv-key 0xB01FA116
gpg: requesting key B01FA116 from hkp server pool.sks-keyservers.net
gpg: keyserver timed out
gpg: keyserver receive failed: keyserver error
Is there any possibility to set up keys manually and continue with installation? Thank you all in advance,
Originally posted by altella on ROS Answers with karma: 149 on 2015-06-26
Comment by Bill Warner on 2015-06-26:
Have you tried just going ahead and installing (e.g. sudo apt-get install ros-indigo-desktop-full)? What errors do you get when attempting that?
The keyserver seems to be back up now. If it goes down again you can use this to get the key from github over an SSL connection.
wget https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -O - | sudo apt-key add -
Originally posted by tfoote with karma: 58457 on 2015-06-26
Post score: 5
