I am running ROS Hydro with Ubuntu 12.04 through VMWare Fusion in an iMac and I'm trying to get my Kinect (model 1414) to work thourgh OpenNI (I've installed openni-camera, openni-launch, and SensorKinect) but when I try to run rosrun rviz rviz
or rosrun image_view image_view image:=/camera/rgb/image_color
I get no image feed.
rostopic list
gives me the normal list of published topics (camera/rgb/image_color, etc) but trying rostopic hz
only shows "subscribed to [/camera/rgb/image_color]" and nothing else.
I read here that Kinect won't work well with a virtual machine, but VMWare is detecting the Kinect:
[ INFO] [1435156294.654805782]: Search for device with index = 1
[ INFO] [ INFO] [1435156294.654805782]: Searching for device with index = 1
[ INFO] [1435156294.908955422]: Opened 'SensorKinect' on bus 1:8 with serial number 'A00365A11201047A'
[ INFO] [1435156295.419182205]: rgb_frame_id = '/camera_rgb_optical_frame'
[ INFO] [1435156295.420168604]: depth_frame_id = '/camera_depth_optical_frame'[1435156294.908955422]: Opened 'SensorKinect' on bus 1:8 with serial number 'A00365A11201047A'
I also selected that Linux takes the Kinect connection instead of the Mac, so VMWare shows the following connections:
Microsoft Xbox NUI Audio, Microsoft Xbox NUI Motor, & Microsoft Xbox NUI Camera
Should I give up on VMWare and try a local installation or am I missing something in the Kinect/ROS/OpenNI installation? Thanks.
Originally posted by Fancyvase on ROS Answers with karma: 21 on 2015-06-24
