Hi,
I'm writing a node, that advertises multiple services.
Should I use a diffrent object name for each service, or the same name (see below)? As I understand it, this results in either multiple instances of a ros::ServiceServer Object, or a single one in the latter case..
Ex. 1:
ros::ServiceServer service1 = nodeHandle.advertiseService("serviceOne", serviceOneFunction); ros::ServiceServer service2 = nodeHandle.advertiseService("serviceTwo", serviceTwoFunction);
Ex. 2:
ros::ServiceServer service = nodeHandle.advertiseService("serviceOne", serviceOneFunction); ros::ServiceServer service = nodeHandle.advertiseService("serviceTwo", serviceTwoFunction);
Which Option should I choose? Is there anything else to remember, while writing nodes, that advertise multiple services?
Thanks
Originally posted by Reiner on ROS Answers with karma: 61 on 2015-06-24
The first one. The second one doesn't even compile.
Originally posted by dornhege with karma: 31395 on 2015-06-24
Comment by Reiner on 2015-06-24:
Thanks, this solves my problem completely
Do you have any experience regarding performance, when a node advertises many services?
Comment by dornhege on 2015-06-24:
It's not a function call obviously, but especially if you use a persistent connection in the client it's OK for speed.
