Hello! I recently purchased a Hokuyo UST 10LX, and i'm having a difficult time figuring out how to get power from the Kobuki (Turtlebot 2) to the scanner. There are a few posts on here about getting the software to work with Hokuyo, but i'm still stuck on the hardware side of things! Do we need to connect the +VIN and -VIN to a 12v supply on Turtlebot? If anyone could shed some light / share their knowledge I would greatly appreciate it!
Link to info about each wire in power cord: http://www.hokuyo-aut.jp/02sensor/07scanner/ust_10lx_20lx.html
Detailed Picture of connector: https://drive.google.com/file/d/0B5Uzsg5R6AysbV9taTFIV25KZ1A1TThwdFNzZUQxMWhpcmo4/view?usp=sharing
Size of connector: https://drive.google.com/file/d/0B5Uzsg5R6AysT0VUUzI3cHVzMEYzbnlDaFVSS01lR0hUNkFj/view?usp=sharing Thank you for your time!
Originally posted by fantasticmsfo on ROS Answers with karma: 21 on 2015-06-23
The cable wiring is as follows: Red: COM Input + Gray: COM Output - Light Blue: IP Reset Input Orange: Synchronous Output Brown +VIN (12VDC / 24VDC) Blue: -VIN Since I plan on using the Ethernet connection for communication, I only need to connect the brown and blue cables for power.
Originally posted by fantasticmsfo with karma: 21 on 2015-06-24
