I have been trying to debug my rosnode with gdb because I am getting a segmentation fault. My package name is renv and the executable inside it is names env
I can run rosrun renv env --env 1 and it works. When I do rosrun renv env --env 2 it gives me a SegFault.
I tried:
gdb --args rosrun renv env --env 2 and gdb says rosrun is not executable (makes sense as it's a shell script)
gdb --args renv env --env 2 and gdb says renv not found
gdb --args env --env 2 and gdb gets confused and trued running /usr/bin/env
I have enabled debugging symbols in CMake using
if(MSVC)
  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /Zi")
else()
  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -g")
endif()
And I find a lot of answers pointing to Roslaunch nodes and gdb + valgrind ... and It's difficult for me to understand that ... I think it says to use gdb --args for the gdb part - But I don't know what to put after that :P
Originally posted by AbdealiJK on ROS Answers with karma: 98 on 2015-06-13
Use the --prefix option to rosrun:
rosrun --prefix 'gdb --args' renv env --env 2
Originally posted by ahendrix with karma: 47576 on 2015-06-13
Post score: 4
Comment by AbdealiJK on 2015-06-13:
This makes complete sense but I never knew the --prefix option existed. Thanks !
Comment by physincubus on 2016-02-05:
supremely helpful
