Hi all,
I have some trouble implementing the navigation stack for one omnidirectional robot. The transfornation -and Odom publisher are done and work fine. I have read Navigation Tutorial and i have adjusted my files so that the application could operate without a static map. So when I launched my files and start sending a goal, the robot rotate endless.
Has anyone an idea about this issue? Here ist my setup for the navigation Stack:
Base local planner:
  TrajectoryPlannerROS:
  max_vel_x: 50
  min_vel_x: 10
  max_rotational_vel: 0.1
  min_in_place_rotational_vel: 0.1
  acc_lim_theta: 0.6
  acc_lim_x: 2.5
  acc_lim_y: 2.5
  holonomic_robot: true
  meter_scoring: true
Coastmap common:
obstacle_range: 2.5
raytrace_range: 3.0
footprint: [ [0.37, 0.33], [-0.37, 0.33], [-0.37, -0.33], [0.37, -0.33] ]
#footprint_padding: 0.01
inflation_radius: 0.55
observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: /base_laser_front_link, data_type: LaserScan, topic: scan_front, marking: true, clearing: true}
Global coastmap:
global_costmap:
  global_frame: map
  robot_base_frame: base_link
  update_frequency: 0.4
  static_map: false
  rolling_window: true
  width: 3.0
  height: 3.0
  resolution: 0.005
  origin_x: -1.5
  origin_y: -1.5
Local coastmap:
local_costmap:
  global_frame: odom
  publish_frequency: 2.0
  static_map: false
  width: 3.0
  height: 3.0
  resolution: 0.01
  origin_x: -1.5
  origin_y: -1.5
Move base:
<launch>
<node pkg="gmapping" type="slam_gmapping" name="slam_gmapping" >
        <remap from="scan" to="scan_front" />
        <param name="map_update_interval" value="0.2" />
</node>
  <node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
    <param name="controller_frequency" value="0.8"/>
    <rosparam file="$(find miagy_2dnav)/costmap_common_params.yaml" command="load" ns="global_costmap" />
    <rosparam file="$(find miagy_2dnav)/costmap_common_params.yaml" command="load" ns="local_costmap" />
    <rosparam file="$(find miagy_2dnav)/local_costmap_params.yaml" command="load" />
    <rosparam file="$(find miagy_2dnav)/global_costmap_params.yaml" command="load" />
    <rosparam file="$(find miagy_2dnav)/base_local_planner_params.yaml" command="load" />
  </node>
</launch>
Source file to send a goal:
#include <ros/ros.h>
#include <move_base_msgs/MoveBaseAction.h>
#include <actionlib/client/simple_action_client.h>
typedef actionlib::SimpleActionClient<move_base_msgs::MoveBaseAction> MoveBaseClient;
int main(int argc, char** argv){
  ros::init(argc, argv, "simple_navigation_goals");
  //tell the action client that we want to spin a thread by default
  MoveBaseClient ac("move_base", true);
  //wait for the action server to come up
  while(!ac.waitForServer(ros::Duration(5.0))){
    ROS_INFO("Waiting for the move_base action server to come up");
  move_base_msgs::MoveBaseGoal goal;
  //we'll send a goal to the robot to move 1 meter forward
  goal.target_pose.header.frame_id = "base_link";
  goal.target_pose.header.stamp = ros::Time::now();
  goal.target_pose.pose.position.x = 1.0;
  goal.target_pose.pose.orientation.w = 1.0;
  ROS_INFO("Sending goal");
  ac.sendGoal(goal);
  ac.waitForResult();
  if(ac.getState() == actionlib::SimpleClientGoalState::SUCCEEDED)
    ROS_INFO("Hooray, the base moved 1 meter forward");
  else
    ROS_INFO("The base failed to move forward 1 meter for some reason");
  return 0;
Any help will be appreciate. Thanks
Originally posted by Lil Kmer on ROS Answers with karma: 23 on 2015-06-12
Comment by czhang on 2015-08-13:
I have exactly the same problem with the navigation stack. Did you solve it? Thanks.
Comment by lfr on 2016-06-02:
Me too. If you have found a solution...
Comment by quentin on 2016-09-02:
same here...
Comment by Pi Robot on 2016-09-02:
Are you sure you want max_vel_x = 50 and min_vel_x = 10? These are in meters per second so 10 m/s is approximately 22 mph or 36 km/h. Also, your global resolution is 0.005 m which is just 5mm. Is your odometry that accurate? Finally, why do you set the controller_frequency so low (0.8 Hz)?
Comment by dottant on 2016-10-25:
same problem here. Solutions???
Hi there,
In my case, the robot was rotating for ever without starting the navigation (even though the global path was computed and drawn on rviz). The reason for this behavior was a too small maximum translational acceleration: it was basically not sufficient to start the motion!! I just increased it and it worked
Originally posted by quentin with karma: 123 on 2016-09-06
