I want to use the MoveIt! package on ROS indigo, and I am following the tutorial at http://docs.ros.org/hydro/api/pr2_moveit_tutorials/html/planning/src/doc/move_group_interface_tutorial.html.
As an example of how to use MoveIt! in C++, the tutorial provides the following line:
moveit::planning_interface::MoveGroup group("right_arm");
What I am trying to figure out, is how to actually compile this. So, I have built a new ROS package, and in the CMakeLists.txt file for that package, I need to specify where to look for header and library files. But how do I know the name of the package that is required for the above code?
If I look in /opt/ros/indigo/include, there are various directories such as moveit, moveit_msgs, moveit_planners_ompl, and similarly in /opt/ros/indigo/lib and /opt/ros/indigo/share. Is each of these directories a package, or is each one a node, or something else?
After doing a bit of research, I found that the moveit::planning_interface::MoveGroup class from the above code is defined in /opt/ros/indigo/include/moveit/move_group_interface/move_group.h. This suggests to me that I should be using the moveit or move_group_interface packages, but if I try either of these, then it fails. For example, in my CMakeLists.txt file, if I have:
find_package(catkin REQUIRED COMPONENTS roscpp rospy std_msgs genmsg moveit)
And then I try to build my package, it tells me:
Could not find a package configuration file provided by "moveit"
And similarly for move_group_interface.
So I'm obviously a bit confused as to what ROS packages actually are, where they are stored on my machine, and how to know which one I should be referencing in CMakeLists.txt. Any help? Thanks :)
Originally posted by Karnivaurus on ROS Answers with karma: 133 on 2015-05-25
Comment by gvdhoorn on 2015-05-26:
Isn't this a sort-of duplicate of Writing a simple CMakeLists.txt file for ROS?
Comment by Fleurmond on 2015-05-26:
That could be true. But I think the title of both questions are really evasive. Then, it could be hard to find is someone already asked this question. And theirs problems look different.
I had same problem here : http://answers.ros.org/question/249354/how-to-install-move_group_interface-from-source/ The solution for move_group_interface is
   moveit_ros_planning_interface
Originally posted by robbycandra with karma: 71 on 2016-12-04
In case it helps anyone else, I made a list of all the package names:
  • moveit_commander moveit_core
  • moveit_fake_controller_manager
  • moveit_msgs
  • moveit_planners_ompl
  • moveit_ros_benchmarks
  • moveit_ros_benchmarks_gui
  • moveit_ros_control_interface
  • moveit_ros_manipulation
  • moveit_ros_move_group
  • moveit_ros_perception
  • moveit_ros_planning
  • moveit_ros_planning_interface
  • moveit_ros_robot_interaction
  • moveit_ros_visualization
  • moveit_ros_warehouse
  • moveit_setup_assistant
  • moveit_simple_controller_manager
  • rqt_moveit
And includes are of the form:
#include <moveit/[namespace]/[header].h>
E.g.:
#include <moveit/robot_model_loader/robot_model_loader.h>
Originally posted by boone with karma: 21 on 2016-12-16
Comment by gvdhoorn on 2016-12-18:
Note that this isn't really moveit specific: this is the regular include pattern for all ROS C++ packages.
