I'm currently calibrating the MPU6050 chip using an arduino mega 2560. I am using the J Rowberg 12c dev libraries. I can get it to print raw accelerometer and gyroscpe values (very unstable, wildly changing values). In the digital motion processing chip library, I can get it to print euler angles, quaternions, real world acceleration and actual acceleration but there is no option to get gyroscope data.
can I use the DMP library to get gyro data or is it only possible to get raw unprocessed gyro values?
I went through the header files of the 12cdev lib and I figured it out.
you have to first add the line VectorInt16 gyro; to your motion variables, then you add the line
mpu.dmpGetGyro(&gyro, fifoBuffer);
to your outputs.
  • $\begingroup$ Any chance you could add a link to the libraries? $\endgroup$
    – uhoh
    Oct 11, 2017 at 10:33
    $\begingroup$ The library is no longer supported but you can grab it here. It is prone to crashing though so you need to do some troubleshooting with the library. github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050 $\endgroup$
    – Ozymandias
    Dec 11, 2017 at 13:40
  • $\begingroup$ Thanks for the reply! OK I'll take a look at it and see what I can learn. $\endgroup$
    – uhoh
    Dec 11, 2017 at 15:27
