Hi, I just got an iRobot Create 2, see the link http://www.irobot.com/About-iRobot/STEM/Create-2.aspx
I tried to use ROS on it; soon, I find it is not that straightforward. Here are what I did so far. I installed ROS Indigo on a virtual machine with Ubuntu 14.04. Then, I looked for the package related to this iRobot Create 2 on the ROS.org, this is what I found http://www.ros.org/browse/search.php?distro=indigo&q=iRobot
Then, I installed the create_driver in my Indigo ROS. I think this driver is for iRobot Create not iRobot Create 2. Here, I want to ask for help. Does anyone here have some experience on how to make iRobot Create 2 move via ROS Indigo? Thanks! If you are interested or also stuck as me, we may team up to figure this out.
Originally posted by intelife_robot on ROS Answers with karma: 1 on 2015-05-17
Comment by luc on 2015-08-05:
Feel free to check here from time to time: https://github.com/lucbettaieb/create_2_drivers
Hi,
we have a working ros indigo node for the Create2. https://github.com/MirkoFerrati/irobotcreate2ros
You will also find a joystick demo that allows you to move the robot via teleoperation. We are still missing some features, but you should be able to move, use the LCD screen and read sensors and odometry out of the box!
Bye, Mirko
Originally posted by mirko.ferrati with karma: 16 on 2015-10-09
Comment by Mario on 2016-01-27:
Miko, I see that your source code have directory called gazebo What do you use gazebo for?
Comment by mirko.ferrati on 2016-01-28:
In the package we also provide a urdf model of the irobotcreate, inside the folders model and gazebo you can find the xacro files, while in the iRobot folder you can find the urdf.
