If I run:
rosrun image_view stereo_view stereo:=raw_stereo image:=image_rect _approximate_sync:=true
I see the correct left and right channels of my stereo camera and a stereo depth map.
However, if I use roslaunch to run the equivalent launch file:
<launch>
    <node name="stereo_view" pkg="image_view" type="stereo_view">
        <param name="stereo" value="raw_stereo" />
        <param name="image" value="image_rect" />
        <param name="_approximate_sync" value="true" />
    </node>
</launch>
all I see are gray screens. What is the difference in the launch file that causes it to fail?
Originally posted by Cerin on ROS Answers with karma: 940 on 2015-05-11
It's caused by the usage of rosrun:
To set parameters when calling a node with ros run the syntax is:
rosrun package node _parameter:=value
To remap a topic when calling a node with ros run the syntax is:
rosrun package node topic_name:=remapped_topic_name
Note the lack of _ prefix before the topic_name! (See: http://wiki.ros.org/rosbash#rosrun )
Therefore in the example you've given stereo and image are topics and approximate_sync is a parameter. Hence, you cannot set stereo and image as parameters in the roslaunch, you must use the remap tag (See http://wiki.ros.org/roslaunch/XML/remap ). I think the correct launch equivalent would be something like:
<launch>
        <remap from="stereo" to="raw_stereo" />
        <remap from="image" to="image_rect" />
        <param name="approximate_sync" value="true" />
    </node>
</launch>
Originally posted by Wolf with karma: 7555 on 2015-05-12
