I have recently written an rqt plugin gui in C++ based on the rqt_image_view plugin.
Everything was working fine until I decided to add another C++ file to my project. This file contains basically a set of useful functions and classes.
After adding it as a library in the CMakeLists.txt, catkin_make is working fine and I am getting no build error.
Moreover, as long as I don't use any functionality from that source file, my plugin loads and works fine. And even if I use stuff from the associated header file, still the plugin loads and works fine.
The issue happens when I actually use that source file in my plugin code. What happens is that although everything still builds, the plugin simply refuses to load, and I get this error message:
RosPluginlibPluginProvider::load_explicit_type(myGUI) failed creating instance PluginManager._load_plugin() could not load plugin "myGUI": RosPluginlibPluginProvider.load() could not load plugin "myGUI"
I am guessing that it might be related to the plugin.xml since there I specify the library path to be that of the gui only. Should I maybe add the path of the library related to my source file? how to do that?
Note that I currently have 2 add_library statement in my CMakeLists.txt: one for the gui and one for the added source file. If I add both of them in one add_library statement, the plugin fails to load even if I don't use the code from the additional source file.
EDIT
This is the relevant part of my CMakeLists.txt:
add_library(helperLib src/additionalSourceFile.cpp)
include_directories(${rqt_my_gui_INCLUDE_DIRECTORIES} ${catkin_INCLUDE_DIRS})
add_library(${PROJECT_NAME} ${rqt_my_gui_SRCS} ${rqt_my_gui_MOCS} ${rqt_my_gui_UIS_H})
target_link_libraries(${PROJECT_NAME} ${catkin_LIBRARIES} ${QT_QTCORE_LIBRARY} ${QT_QTGUI_LIBRARY} helperLib)
And the plugin.xml: (I am guessing the 1st line should be modified in some way to include the other helper library path)
<library path="lib/librqt_my_gui">
   <class name="myGUI" type="rqt_my_gui::myGUI" base_class_type="rqt_gui_cpp::Plugin">
    <description>
      A GUI plugin
    </description>
    <qtgui>
      <group>
        <label>Robot Tools</label>
      </group>
      <label>My GUI</label>
      <icon type="theme">applications-other</icon>
      <statustip>User interface to allow interaction.</statustip>
    </qtgui>
    </class>
 </library>
Originally posted by beginner on ROS Answers with karma: 83 on 2015-05-05
Comment by Dirk Thomas on 2015-05-05:
Sharing your code might help others to help you.
Comment by beginner on 2015-05-05:
Added code in the edit... I really hope that someone can help!
This error does not necessarily mean that rqt failed to find and load your library file. If you are saying
the lib itself is most likely found but there are some issues when loading the classes/functions in it. A very common mistake that causes this behaviour is declaring (and using) a function that is not defined (implemented); or function declaration and definition do not match. When creating an exec this would cause a linking error but as you are just creating a lib in your project (that is loaded outside your project) the linker will assume that undefined references will be resolve somewhere else when creating the lib. So always double-check all function definitions are declared and definitions and declaration match...
Originally posted by Wolf with karma: 7555 on 2015-05-06
Comment by beginner on 2015-05-06:
Apparently, you are right! I tried using a simple source file with simple functions, and everything worked like a charm :) I still need to figure out why my original source file is not working though (it is compiling without errors)
Comment by Wolf on 2015-05-06:
check all function signatures are identical, and of cource make sure your new cpp file is amongst ${rqt_my_gui_SRCS}
checked, but still not working :(
can you post the code of your cpp files and header?
Thanks... I figured it out :D It was a missing definition for a class method which I wasn't using... ughhhhh
Comment by ivaughn_whoi on 2019-12-27:
Anyone have better advice on how to get ANY detail on the linker errors? I just get "could not load plugin", even though the library definitely exists.
You can check for missing symbols with ldd -r devel/lib/<your_library_here>.so, but it would be lovely if there was a way to ask pluginlib to dump debug info.
