To finish installing ros-jade-desktop-full on Trusty, I had to uninstall Gazebo2 and install Gazebo5 related packages, which break many Indigo packages that transitively depend on Gazebo2 (via gazebo_ros etc.) I see at least 2 problems here:
  • (As of now) there doesn't seem to be rosdep keys for ros-indigo-gazebo5* packages, which is suggested here. So I'm afraid changing dependencies in the package.xml files for the packages that depend on gazebo is not yet possible (e.g. I get $ rosdep install --from-paths src --ignore-src -r -y --> Cannot locate rosdep definition for [gazebo5_ros_control]).
  • In the first place Indigo's official hosted Gazebo version is 2.x, based on which I bet there are projects that define the system requirement.
Is there any solution to keep me working on both ROS Indigo and Jade on the same OS, using both Gazebo2 and 5?
Originally posted by 130s on ROS Answers with karma: 10937 on 2015-05-01
Post score: 4
Comment by Martin Günther on 2015-05-26:
Same here. The deb packages sdformat-sdf and libsdformat2, which Jade depends on, collide with libsdformat1, which Indigo depends on.
There is not, we knew going into this that gazebo2 and gazebo5 could not be installed side-by-side and that would mean that ros-indigo-gazebo-ros-pkgs and ros-jade-gazebo-ros-pkgs could not be side-by-side installed. See: https://github.com/ros-infrastructure/rep/pull/89#issuecomment-67402826
Originally posted by William with karma: 17335 on 2015-06-03
