BH
I'm using gazebo 2.2.5 version with Ubuntu TRUSTY. I would like to launch the turtlebot_world.launch file in order to operate a turtlebot with the kobuki_keyop package in an empty world. While launching the file, I get this error: Invalid tag: environment variable 'TURTLEBOT_GAZEBO_WORLD_FILE' is not set.
Arg xml is The traceback for the exception was written to the log file
How can I set the TURTLEBOT_GAZEBO_WORLD_FILE parameter so that the command will work?
Seeking forward for ones help
Originally posted by Haz88 on ROS Answers with karma: 41 on 2015-05-01
Comment by Javier V. Gómez on 2015-05-13:
Have you installed ros-indigo-turtlebot-gazebo?
Comment by abhay2302 on 2016-12-15:
open a new terminal and than try. hope that may work.
Comment by jaskaranvirdi on 2017-04-04:
It did work after opening the terminal again. Maybe because the environment variable wasn't loaded.
3 Answers 3
It asks for a world file, so give it a world file. Something like
roslaunch turtlebot_gazebo turtlebot_world.launch world_file:=/opt/ros/indigo/share/turtlebot_gazebo/worlds/playground.world
Originally posted by Girts L with karma: 196 on 2016-07-28
Post score: -1
Comment by 130s on 2016-09-27:
This MAY work for now, but you should really stick to the way the package developers support. See the link in my answer.
Turtlebot utilizes environment variables that are set by env hook. See this tutorial.
Originally posted by 130s with karma: 10937 on 2015-09-01
use the folowing command
rosmake turtlebot_gazebo
it will build the packages installed
Post score: 5
Comment by danielsnider on 2017-04-23:
Worked for me in kinetic:
export TURTLEBOT_GAZEBO_WORLD_FILE=/opt/ros/kinetic/share/turtlebot_gazebo/worlds/playground.world
