installing PCL 1.7.2 under Indigo compile from source. How can I find out which ros packages I need to download from source to recompile for compatability? I am getting errros like:
Update: I downloaded pcl_ros and pcl_msgs and compiled from source by I am still getting these odd errors. Do I need to do somthing with ros-gbp/pcl-release? Should I download and add a track for Indigo pcl 1.7.2? Anyhelp here please.
Linking CXX executable /home/richard/catkin_ws/devel/lib/testPCD/testPCD
CMakeFiles/testPCD.dir/src/testPCD.cpp.o: In function `TestPCD::sendCloud(boost::shared_ptr<sensor_msgs::PointCloud2_<std::allocator<void> > const> const&)':
testPCD.cpp:(.text._ZN7TestPCD9sendCloudERKN5boost10shared_ptrIKN11sensor_msgs12PointCloud2_ISaIvEEEEE[_ZN7TestPCD9sendCloudERKN5boost10shared_ptrIKN11sensor_msgs12PointCloud2_ISaIvEEEEE]+0xa0): undefined reference to `pcl::ProgressiveMorphologicalFilter<pcl::PointXYZ>::ProgressiveMorphologicalFilter()'
make[2]: *** [/home/richard/catkin_ws/devel/lib/testPCD/testPCD] Error 1
make[1]: *** [gazebo_ros_demos/testPCD/CMakeFiles/testPCD.dir/all] Error 2
Makefile is as follows:
project(testPCD)
  roscpp
  tf2_ros
  std_msgs
  geometry_msgs
  sensor_msgs
  actionlib
  actionlib_msgs
  pcl_ros
## System dependencies are found with CMake's conventions
find_package(Boost REQUIRED COMPONENTS system)
find_package(PCL 1.7.2 REQUIRED)
catkin_package(
  DEPENDS boost
  LIBRARIES
  CATKIN_DEPENDS
  tf2_ros
  std_msgs
  geometry_msgs
  sensor_msgs
  actionlib
  actionlib_msgs
  pcl_ros
## Build ##
 include_directories(include ${catkin_INCLUDE_DIRS} ${catkin_INCLUDE_DIRS} ${PCL_INCLUDE_DIRS})
 add_executable(testPCD src/testPCD.cpp)
 target_link_libraries(testPCD ${catkin_LIBRARIES}  ${Boost_LIBRARIES} ${PCL_LIBRARY_DIRS})
 add_definitions(${PCL_DEFINITIONS})
Originally posted by rnunziata on ROS Answers with karma: 713 on 2015-04-26
Comment by Maya on 2015-05-03:
Did you install PCL from source or the repo ? Culd you post your CMakeList.txt ?
Comment by rnunziata on 2015-05-03:
Updated question with requested data
I had some errors in my makefile the following changes allowed the pgm to compile without error.
include_directories(include ${catkin_INCLUDE_DIRS} ${catkin_INCLUDE_DIRS} ${PCL_INCLUDE_DIRS}) link_directories(${PCL_LIBRARY_DIRS})
set(PCL_BUILD_TYPE Release)
target_link_libraries(testPCD ${catkin_LIBRARIES} ${PCL_LIBRARY} ${Boost_LIBRARIES})
Originally posted by rnunziata with karma: 713 on 2015-05-05
